Configuration of buttons sensitive for touch screen displays.
Toni
by Toni » Wed May 23, 2012 5:18 pm
My client will display the virtual tour in touch screen displays. They are complaining the navigation buttons and zoom are not so responsive in the touch screen, whitout sensitive and working intermittent. Please there's any sensitive configuration for this ? Or this is a problem that should be resolved in the touch display or OS ?
Toni
by mediavets » Wed May 23, 2012 5:32 pm
Toni wrote:Hi,
Toni
I think this is a touchscreen hardware and driver issue.
What brand and model of touch screen do they use?
Toni
by Toni » Sat May 26, 2012 3:33 am
Hi Andrew,
I don't know yet which model and brand they tested it.
As recommended by kolor support, I changed moveforce value for zoom in and out. Waiting for a feedback if it's working nice now.
Thanks a lot for your attention !
Toni
by klausesser » Sat May 26, 2012 1:23 pm
Toni wrote:Hi Andrew,
Toni
Hi Toni!
As Andrew said: the touch *senitivity* is related to the hardware-settings of the device. The *speed* of zooms you can set in the xml afaik.
