Best settings for the new iPad (3rd gen) :: Cube Face :: Cutting Size
Toni
by Toni » Sun May 20, 2012 2:58 am
I've already searched the forum but didn't found any info about it. If anyone could help me I greatly appreciate :)
What's the best settings for Cube Face Size and Cutting Size to allow max resolution in the new iPad 3rd generation ?
Sorry if is a dumb question:
If the new iPad resolution is 2048-by-1536 pixels, this means I can have a 2048 cube face with a 8.192 x 4.096 equiretangular pano ?
I read in the forum that the multi resolution features (cutting size) only works in flash, so can I disable it and leave in "0" ?
Thanks a lot
Toni
by mediavets » Mon May 21, 2012 8:59 am
May I suggest that you (re)post this question in the Panotour/Panotour Pro section of the forum; then you will be more likely to get an answer.
