Embeding XML files - speed difference?
deedee7
by deedee7 » Sun Apr 22, 2012 3:08 pm
Hello.
My 5-pano virtual tour is about 30 MB.(no sound but google map and pano thumbnails are enabled). Input panos are 3000x6000 pix (jpeg quality 8). Would unchecking "Embed XML files" box speed things up when viewing online? Can't check it myself, because running demo version PTP 1.6.
Thank you.
P.S. when I view it locally - it takes like a minute for the 1 pano to load :(
by gkaefer » Sun Apr 22, 2012 3:15 pm
ohhh YEEEES. personal I never use this embedded option because all panos must be preloaded before getting displayed. and this makes no fun if more than 1 pano is used.
jpg level 8 is good for speed to. e.g. jpg level 12->10 reduces filesize on harddisc of the pano more than 50%. So here for fisheye panos I tend to use 10 and for 85mm panos I rather tend to jpg level 8 to keep quality and size in balance.
PS pixel size you mention: you mean 6000 x 3000 or really 3000 x 6000 (which should not work at least as full spherical pano)?
if you can put your demo tour online and provide a link than we could crosstest the speed...
deedee7
by deedee7 » Sun Apr 22, 2012 3:22 pm
Hey!
Thanks for a quick reply!
Yes, I meant 6000 x 3000 :p
Can't put it online because it's only a demo ver.
jeradg
by jeradg » Thu Apr 26, 2012 8:06 pm
definitely don't embed all. my pano went from 20-30 seconds loading to 1-2 seconds per pano. when someone is trying to view your tour they will get bored with the initial wait, but will deal with a blurred loading for a second or two.
deedee7
by deedee7 » Wed May 02, 2012 8:36 pm
Hey. So this time I didn't embed XML (PTP 1.8) and , sadly, my local and online load times are still very slow- 90sec. for the first pano and about 35 for the rest. My computer isn't the fastest but it's an i7 quad with 8GB RAM so that shouldn't be the problem. My download speed is about 22Mbps. Like I said before,my source panos are 6000x3000, jpg quality 8. After I click the reduce distortion button I get 1888 cube face size and 120 cutting size. No sound, no video.
Here's the link to the tour: http://virtuastudio.pl/vir/restauracja%20szczecin/rs.html
by mediavets » Wed May 02, 2012 9:00 pm
deedee7 wrote:Here's the link to the tour: http://virtuastudio.pl/vir/restauracja%20szczecin/rs.html
It's considerably faster than that for me (here in the rural UK) and my ADSL Net connection is at best about 1.5Mbps.
Getting rid of the little planet intro will probably speed up loading of initial pano.
When you say 'load time' at what point do you consider the pano to be 'loaded'?
deedee7
by deedee7 » Wed May 02, 2012 9:28 pm
Hey. Thanks for a quick reply. By load time I mean the time from the moment the little wheel in the middle appears to the moment it stops spinning.
by gkaefer » Wed May 02, 2012 11:13 pm
deedee7 wrote:Hey. Thanks for a quick reply. By load time I mean the time from the moment the little wheel in the middle appears to the moment it stops spinning.
I use an asynchronus xdsl link with 5mbit downlink.
From cklicking on link in thread until little planet has finished: 16 seconds.
... and my ADSL line is quit exotic: postal splitter & xdsl modem is in base level. from here its going via 10mbit via powerline link to my cellar where my firewall and wireless lan router is placed and with N band its going wireless to second level to my PC...
Liebe Gruesse,
shane999
by shane999 » Thu May 03, 2012 12:11 pm
Checked the link and it loaded pretty quickly like under 10 seconds. And my internet is just a 1mb line (in Sri Lanka). And yea it might get faster if you get rid of the little planet intro..
Cheers..
Canon 5D Mark II - Canon 50D - Canon 8-15mm - Canon 10-22mm
deedee7
by deedee7 » Thu May 03, 2012 3:08 pm
Thanks everyone for your tests!
I've solved the problem by increasing the cutting size from 120 to 478. Panos load in just a few seconds now! :) I had no idea that cutting size can influence load time.
by mediavets » Thu May 03, 2012 3:44 pm
deedee7 wrote:Thanks everyone for your tests!
Why did you change the cutting size value from the default?
deedee7
by deedee7 » Fri May 04, 2012 2:06 am
I did it, because simply not embedding XML didn't improve load times. I've read somewhere on this forum about cutting size and decided to experiment with it. There is a significant speed difference (at least from where I'm sitting) in pano load times both locally and online. I've put it online for you to verify.
http://virtuastudio.pl/vir/muzeum%20techniki/muzeum.html (faster)
http://virtuastudio.pl/vir/muzeum%20techniki/cut120/cut120.html (slower)
Parameters of both tours are identical: XML not embedded, jpg 8, source panos 6000x3000, "reduce distortion" used.
The only difference is that in the first tour cube face is 1904 and cutting 478 whereas in the second cube face is 1888 and cutting 120.
The way I do it is enter the cutting size manually and click "reduce distortion" to get the optimum cube face size.
by gkaefer » Fri May 04, 2012 10:24 am
I never use the default value. But I also never enter manually a value. Teh optimize button is gold worth and did work for me allways perfectly.
and this "optimized" value varies allways - I think it depends on panosize/dimensions...
