Video embedding in iBook widget
electroniceye
by electroniceye » Wed Apr 18, 2012 2:29 pm
Hello all,
I've embedded an .mp4 video on a virtual tour widget for iBooks. Unfortunately, iBooks Author keeps on saying the video format isn't supported.
I've modified the xml file to run the videoplayer.js like I do for regular "online" tour w/o any success so far.
Does anyone know if this is an iBooks limitation or if any workaround exists.
Thanks for the heads up
Regards
-David
http://www.electronic-eye.com
Interactive Imagery for luxury markets
BrunoM
by BrunoM » Wed Apr 18, 2012 3:45 pm
HI ,
'hope this'll helps : http://support.apple.com/kb/PH2791
I had the same problem. How weird uh?!
Bru
electroniceye
by electroniceye » Wed Apr 18, 2012 3:46 pm
And did it finally work for you?
Thank you for helping!
Cheers
-D
electroniceye
by electroniceye » Wed Apr 18, 2012 4:06 pm
Bruno,
I gave a try and exported using the “iPod touch & iPhone 3GS.” Unfortunately it creates a .m4v video which is compliant with ibooks html widget video format but not when embedded in the PTP widget...
Any thoughts?
Thanks again
-D
Toni
by Toni » Wed Jun 06, 2012 7:07 pm
I'm having exactly the same problem. Even exporting via quicktime for m4v and iphone version.
Any update on this issue ? Have anyone successfully inserted a video inside a virtual tour widget in iBook ?
Thank you
Toni
electroniceye
by electroniceye » Wed Jun 06, 2012 7:29 pm
Hello Toni,
I did not get a chance to proceed to further testing so far. I'll let you know once I find sth suitable for all.
Regards
-D
Mickeel
by Mickeel » Sun Mar 31, 2013 5:19 pm
Is there any solution for video inside our panotour now?
Especially for more than 1 video hotspot :|
Or is there any way we can link the hotspot to a page inside the ibook?
