Customized Frame/Border/Buttons in Theme Template
Toni
by Toni » Wed Apr 04, 2012 3:32 pm
I've already read the tutorials about creating your own template or using your own graphical theme but didn't found out if it's possible or how to personalize the layout to create a frame, border or buttons inside a panel in the interface.
After starting using Panotour I just loved it, so easy to link between panoramas but it seems to lack an alternative to customize the skin.
I would like to create more professional skins, with borders/frames personalized to my customer brand.
I've seen some productions of that kind of personalized interface but most of them are made with Flash Panorama Player or Flashificator.
When I mean frame/border and personalized buttons like a panel (not separated), it's an example like this:
http://www.ciaathletica.com.br/tour_virtual/2009/estadio/FULLSCREEN/index.html
(Tour made with FPP).
Is there any way to make something similar with Panotour Pro ?
Or this is a function Kolor will make available in future versions ?
I miss a personalized loading and progress bar option too.
Thanks a lot for your support =)
jeradg
by jeradg » Thu Apr 05, 2012 8:25 pm
I am working on figuring out the progress bar stuff also. I know that there is a customizable way to do it.
http://www.autopano.net/wiki-en/action/view/Panotour_Pro_-_Templates will take you to where it talks about the coding.
