Anyway to open w Stereo/pannini/little p view instead of normal view?
ATXcloud
by ATXcloud » Fri Mar 02, 2012 9:08 pm
I have a tour that would look best in Stereographic view. However, when you click on the link it automatically opens in normal view per default. 99.9% of my audience will never discover the ability to right click and select a different view. What do i need to do to build the tour with another view instead?
Howdy from Deep in the Heart of Texas!
ATXcloud
by ATXcloud » Sun Mar 04, 2012 7:16 pm
Okay, So ive looked around and started diving into editing the xml's files... great response from http://www.kolor.com/forum/p61231-2010-04-02-20-49-05
Wondering what is the settings for Stereographic projections? Here is what I have been tooling around so far...
<view fisheye="0" limitview="range" hlookatmin="-120" hlookatmax="180" vlookatmin="-75" vlookatmax="75" fovmin="0.01" fovmax="179" fov="90" hlookat="0" vlookat="0"/>
<action name="tweennormalview">
tween(view.hlookat, -89, 10, easeInOutQuad);
tween(view.vlookat, 20.46, 10, easeInOutQuad);
tween(view.fov , 120, 10, easeInOutQuad );
tween(view.fisheye, 0.0, 10, easeInOutQuad, WAIT);
set(display.flash10, on);
set(view.limitview , range);
set(view.vlookatmin, -90);
set(view.vlookatmax, 90);
set(view.hlookatmin, -180);
set(view.hlookatmax, 180);
set(view.fovmin , 1);
set(view.fovmax , 120);
</action>
wjh31
by wjh31 » Sun Mar 04, 2012 9:25 pm
underneath, PTP is just krpano, so once you get into editing the xml you'll want the refrence on that site ( http://krpano.com/docu/xml/ ), the bit you are after is probably http://krpano.com/docu/xml/#view.stereographic
ATXcloud
by ATXcloud » Tue Mar 06, 2012 6:21 am
Success! I am very happy right now! :cool:
I've been after that tweak for some time... who knows how many hours. With no formal training in code... I've come a long ways, and still many MANY miles to go! I will say, I love what kolor/krpano has inspired me to accomplished.
Enjoy: www.atxcloud.com
