Panotour Pro 1.7.3
reinhardkiss
Panotour Pro 1.7.3
by reinhardkiss » Sun Feb 26, 2012 9:00 am
Panotour Pro 1.7.3.
We have big problems with the new OpenStreetMap plugin.
After export on local host:
only a rotating radar with blank background (no map).
on Webserver:
a graphic with the hint "...MORE OSM COMING SOON".
The Map-Functionality is a mandatory feature in our production and we request your help.
Is there still a bug in the SW our do we make something wrong. Do you provide a step by step tutorial how to use the new feature.
Please get in touch asap, because we have some pressure from our client side.
Thank you
Reinhard
by mediavets » Sun Feb 26, 2012 6:19 pm
As you are probably aware Panotour Pro is a GUI front-end command file generator for the krpano Panorama Viewers - so this thread at the krpano forum is relevant:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=6859
by gkaefer » Sun Feb 26, 2012 7:26 pm
mediavets wrote:As you are probably aware Panotour Pro is a GUI front-end command file generator for the krpano Panorama Viewers - so this thread at the krpano forum is relevant:
see Klaus explaining the situation: http://www.krpano.com/forum/wbb/index.php?page=Thread&postID=36058#post36058
Likes: 14 posts
by bdd » Mon Feb 27, 2012 8:17 am
First, just a quick note for Andrew and Georg, PanotourMaps plugin is a "Kolor made" plugin for krpano viewer.
So your link to krpano's forum on an OpenStreetMap thread is not relevant.
On the OSM problem, could you tell me "where" is localized your map ? At which coordinates ?
And did you clicked on the "Set as default view" icon on the PanotourMaps hotspot editor view ?
If yes, what kind of map was seen when you did it ? Satellite, Street map, or terrain ?
Could you also write here the full XML description of your PanotourMaps plugin in the main XML of your tour ?
It is the line describing the plugina named "panotourmaps". It starts like the following :
    <plugin name="panotourmaps" parent="STAGE" keep="true" devices="flash" url="xxxdata/graphics/PanotourMaps.swf"  ...
by mediavets » Mon Feb 27, 2012 1:35 pm
bdd wrote:First, just a quick note for Andrew and Georg, PanotourMaps plugin is a "Kolor made" plugin for krpano viewer.
Gérald,
Tnanks for that insight. It had never occurrred to me that Kolor would 're-invent the wheel' and create their own Google maps plugin; I guess it seemed like a good idea at the time.
Now however I imagine that you face the same challenges and options as outlined by Klaus in trying to come up with a solution to the withdrawal/deprecation of the Flash API for Google Maps?
Perhaps this is the time for Kolor to work together with Klaus to develop a common solution sooner rather than later?
Aperol
by Aperol » Mon Feb 27, 2012 5:44 pm
HI
i have more or less the same problem.
After created the virtual tour on my computer:
only the zoom and maps controls with blank background (no map).
on Webserver:
as html model i used the fullpage.html , and i activated the iphone/ipad option
i selected satellite as map . i clicked on the "Set as default view" icon .
the map is located here: via rossi 3 rubano pd italia
here is a picture:
Canon 60D / Samyang 8mm fisheye / Sigma 10mm fisheye / NN3 MKII / Manfrotto Xprob055 / Autopano Giga / Panotour Pro
Likes: 14 posts
by bdd » Tue Feb 28, 2012 8:36 am
I do not have any problem displaying this street with OSM.
Did you set a default zoom level for the map by clicking on "Set as default view" icon in the "hotspots editor" window for the PanotourMaps plugin ?
Maybe your zoom level is too high (or too low) for OSM.
Jeremiah
by Jeremiah » Tue Feb 28, 2012 3:31 pm
I have not done any testing, but could it have something to do with "satellite" being chosen as the map type?
OSM doesn't have a satellite option do they?
Aperol
by Aperol » Wed Feb 29, 2012 4:39 pm
hi
im not able to load the map with OpenStreetMap ... also i can see that on Panotour Pro 1.7.3 the default map is still GoogleMap also if i selected OpenStreetMap
Likes: 14 posts
by bdd » Thu Mar 01, 2012 8:15 am
The map displayed inside PTP to configure the map view and the spots position is a GoogleMap and it will stay like this for a while.
Even if you choose another map layer provider for your tour.
yves360
by yves360 » Sun Mar 04, 2012 4:07 pm
Klaus already found a solution ;-)))
http://www.krpano.com/forum/wbb/index.php?page=Thread&postID=36143#post36143
But not working for Panotour :-(
