seting the size of the controler bar
tamiro
Likes: 12 posts
by tamiro » Sat Feb 11, 2012 11:17 pm
i have allredy ask about it but no one anser me so...
how can i set the size of the controler bar?
why it stay so big when the viewing window is samll?
ther is a way to control the size of the controler bar?
Tamir
by mediavets » Sun Feb 12, 2012 12:25 am
tamiro wrote:Is there is a way to control the size of the controler bar?
Tamir
Not via the Panotour/Panotour Pro GUI.
by klausesser » Sun Feb 12, 2012 1:13 am
tamiro wrote:i have allredy ask about it but no one anser me so...
Tamir
You can change the button´s size in an image-editor.
Pano360.co.uk
by Pano360.co.uk » Tue Feb 14, 2012 11:54 am
Hi Tamir,
You can change the size of the controller in the XML for each button, note you will also need to change the x & y positioning so they will all sit in the viewer correctly.
Take a look at the top post on my Facebook page: http://www.facebook.com/Pano360Devon
Needed to change the size of the controller as was too big when I wanted to put the Virtual Tour inside a post on my wall.
You can take a look at the XML here: http://www.pano360.co.uk/virtualtours/social/merlin-farm/treyarnon-cottage/treyarnon-cottage-virtualtour-soc.xml
Curtis.
marin
by marin » Mon Mar 12, 2012 7:34 am
Curtis, how did you proceed to permanent keep the text on thumbnails?
