Create your own template or theme for Panotour Pro
Likes: 14 posts
by bdd » Tue Jan 17, 2012 1:57 pm
2 new tutorials are available for those who want to create their own graphical theme and/or their own menu templates for Panotour Pro.
The first one explains how to create your own graphical theme and use the menus already provided by Panotour Pro resources
No coding skills are required for this one :
Use your own graphical theme
The second one explains how to create your own template.
This tutorial is designed for users who wish to go beyond the behavioral templates and graphical templates offered by Panotour Pro, and who do not want to have to edit XML files after generating a tour in Panotour Pro.
A basic knowledge of krpano syntax is necessary to understand the different points contained in this tutorial :
Creating your own theme templates
PS:
These tutorials are also available in French : http://www.kolor.com/forum/viewtopic.php?id=13925
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Mon Apr 22, 2013 6:14 pm
Great! except I get an error message saying the xml file isnt there! It clearly is!
I think it is easier to hand code that try to work all of this out!
For the next release can you please have a function for zoom, fullscreen and help buttons only.
Also some buttons that look useable (futuristic and minimal), not a 1980's skiing outfit!
I know how to code, but I am giving up after 1.5hrs...
Richard Hart
Commercial and portrait photographer OC California
http://www.richhartphoto.com
johnson33445
by johnson33445 » Mon Jun 17, 2013 4:12 am
Still the truth. If you know of any other gui that is as versatile, you are welcome to mention it.
The proof for my statement is seen in the works of those who use the software. Plain and simple... regardless if it irritates people to be reminded of it or not.
plagiarismsoftware - plagiarism software free
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Wed Jun 19, 2013 10:36 pm
johnson33445 wrote:Still the truth. If you know of any other gui that is as versatile, you are welcome to mention it.
I find it easier to hand code the buttons post panotour...
I am sure I got something to work once, but then it didn't!
I believe the new version allows the opportunity to build templates
Richard Hart
rubenscardia
Re: Create your own template or theme for Panotour Pro
by rubenscardia » Sat Jan 11, 2014 2:07 pm
Hi Fellows,
I'd really loved this tutorial theme, and I wish to use it in my new projects, but I'm facing a little problem: I live and work in Brazil and I'm trying translate the menu captions (move left, move right, help, stop sounds, etc) to Portuguese but I'm facing a little problem, all special letters like "ç , ã, õ" appears as a small block.
Could anyone help me?
by klausesser » Sat Jan 11, 2014 8:40 pm
error.
rubenscardia wrote:Hi Fellows,
did you try an english typeset?
rubenscardia
by rubenscardia » Mon Jan 13, 2014 12:24 pm
Hi Klaus,
When I use an english typeset there is no problem, and I'm using some synonymous to avoid the special letters problem.
But I'm facing another problem, there is an error message showing in my tour, Can you explain me what is wrong and who can I fix it.
thanks and regards.
by klausesser » Mon Jan 13, 2014 1:48 pm
Hi Klaus,
thanks and regards.
I know that definitely it´s not allowed to use any spacing or "special" letter in the data-path!
by mediavets » Mon Jan 13, 2014 2:30 pm
You can edit the control bar icon tooltips very easily.
Does it not work for you?
rubenscardia
by rubenscardia » Mon Jan 13, 2014 3:10 pm
Thanks for the tip, but I'm still using the Panotour pro 1.8
by mediavets » Mon Jan 13, 2014 6:53 pm
Oh dear....sorry I failed to notice the topic you had posted in.
Still now you know what one possible answer is. ;)
