Crossfade transition without losing position?
spyboy
by spyboy » Sun Nov 20, 2011 10:46 pm
I have 2 panos shot from the same location that I want to transition between when a use selects from a drop down menu.
Both images are shot from the same spot and have the identical positioning.
So when the first image loads, if a user rotates to the right a few degrees, then selects the second pano, it should still be at the same spot, but just crossfade.
Is this possible with Panotour?
I've done this by programming the .xml file and just using krpano, but I'm really enjoying building tours with Panotour because it's so much faster.
Kirk
Likes: 14 posts
by bdd » Mon Nov 21, 2011 9:02 am
This feature is not yet in PTP, but is planned for a future release.
Untill then, you still have to add krpano code in the generated XMLs.
xrb360
by xrb360 » Thu Apr 19, 2012 9:30 am
Can anybody show me an XML file , as an example to do that?
Best regards
Xavi
Nelike Imagery
by Nelike Imagery » Thu Apr 19, 2012 11:40 am
Hi!
Check my answer from yesterday from day / night thread.
http://www.kolor.com/forum/p98130-yesterday-12-53-07#p98130
Will work for you perfectly.
Regards,
Jesse Passoja
Nelike Imagery
www.inelike.fi
Latest panoramas: http://inelike.fi/aiheeton/latest-panoramas/
xrb360
by xrb360 » Thu Apr 19, 2012 9:13 pm
Hi
It's simple and perfect.
Thanks a lot Jesse
Xavi
www.espais360.com
