Logo with image link
rammstein
by rammstein » Sat Nov 19, 2011 12:59 pm
http://www.360concept.ro/panorame/masini/tur_vw/ how can i add into my panorama a logo like that from this panorama. (volkswagen golf logo)
I want to add in my pano something like that : when you press click on it to open a picture!
wjh31
by wjh31 » Sat Nov 19, 2011 2:06 pm
rammstein
by rammstein » Sat Nov 19, 2011 10:10 pm
you didn't understand me . I don't want to open a web page when you click on the logo , i want to open an image. Take a look at the link below http://www.360concept.ro/panorame/masini/tur_vw/ PS: if you click on volkswagen logo panorama open an image with some details about that car. This is what i want
rammstein
by rammstein » Sun Nov 20, 2011 4:08 pm
still no answer?
wjh31
by wjh31 » Sun Nov 20, 2011 6:02 pm
It will probably require editing the xml by doing something like this:
In PTP create a hotspot with the image link, and a logo with a regular link then export without xml embeding
Open xml files and copy the appropriate bits from the hotspot to the logo then remove the hotspot
rammstein
by rammstein » Sun Nov 20, 2011 7:08 pm
it doesn't work . maybe instead of onclick="openurl --- i'll change with a script for open image . but maybe you can help me ,, t've searched on goolgle and i didn't fin anything
kevshu
by kevshu » Sun Nov 20, 2011 11:21 pm
I tested what wjh31 said and it works. Make a hotspot that displays an object and choose the image you want. Also have a logo but leave the link blank. Build the tour. Edit the xmls... copy the onclick info and paste it into the logo in the main xml.
For example:
My pano0.xml had a hotspot line of code:
<hotspot name="spot0" onclick="closeallobjects();set(plugin[spot0object].visible,true);tween(plugin[spot0object].alpha, 1);" url="virtualtourdata/graphics/spots/spot0.png" crop="0|0|65|65" frame="0" lastframe="9" frameheight="65" framewidth="65" onloaded="set(stopSequence,false);animate(spot0,0.1);" ath="401.033" atv="2.37323"/>
<plugin name="spot0object" visible="false" url="virtualtourdata/graphics/spots/object0.jpg" align="center" alpha="0" onclick="tween(alpha, 0);delayedcall(0.5,set(visible,false));"/>
copy the onclick="closeallobjects();set(plugin[spot0object].visible,true);tween(plugin[spot0object].alpha, 1);" and paste it after the logo entry in the mail xml (pano.xml)
Original:
<plugin name="logo1" url="virtualtourdata/graphics/logo1.png" keep="true" align="righttop" x="10" y="10" width="550" height="prop" handcursor="false" capture="false"/>
And modified:
<plugin name="logo1" url="virtualtourdata/graphics/logo1.png" onclick="closeallobjects();set(plugin[spot0object].visible,true);tween(plugin[spot0object].alpha, 1);" keep="true" align="righttop" x="10" y="10" width="550" height="prop" handcursor="false" capture="false"/>
Kevin Schumacher
Canon 5Dmk2, 15mm Fisheye, 24-70mm, 100mm Macro, 100-400mm, Nodal Ninja 3
Orion GoTo Mount, BT Ver2 Module, Papywizard on Fujitsu LifeBook U810
yves360
by yves360 » Sun Jul 22, 2012 7:46 am
It works!!!
Thank you very much :)
Yves
yves360
by yves360 » Mon Jul 23, 2012 9:35 am
But its works only on the first pano :(
By the next pano it didn't work because the hotspot that displays an object and choose the image is in the first pano!
If I put manually the same hotspot in xml from the second pano it didn't work too!
