bloggie 360 video panorama, how to unwrap ?
aokaf
by aokaf » Fri Jul 15, 2011 3:59 am
I purchased a sony bloggie with a 360 video lens
I nned to use the result video inside the coming PTP that supports video 360
http://www.kolor.com/blog-en/2011/06/02/palmela-2011-virtual-tours-today-tomorrow/
there was no supporting software !
I couldn't unwarp the video
I googled that, hte only thing I found is videowarp director from gopano 300$
http://eyesee360.myshopify.com/products/videowarp-director
is there any cheaper way ?
vklaffehn
by vklaffehn » Fri Jul 15, 2011 6:42 am
Hi!
I also have that funny bloggie cam, mine has a software called PMB on CD : http://www.sony-mea.com/support/download/316131
and this method I have successfully tried, too : http://www.diy-streetview.org/2010/06/26/sony-bloggie-hacked/
including removing one of the magnets in the lens.
MfG
V.Klaffehn
Also found this : http://www.flong.com/blog/2010/modding-the-bloggie-panoramic-lens-accessory/
aokaf
by aokaf » Fri Jul 15, 2011 10:17 am
I have a mac ?!
is there a mac version ?
aokaf
by aokaf » Fri Jul 15, 2011 10:24 am
my lens is we- bpp2
the one in the photo is we - bpp1
my camera is MHS - TS20K
aokaf
by aokaf » Fri Jul 15, 2011 10:50 am
I downloaded the software, it look just like the one that came with it
there was no (video unwarp)
please help me
RGBaker
by RGBaker » Sat Aug 13, 2011 1:03 pm
First, my Bloggie came with software that would unwrap, so not sure why yours didn't.
But I found better, and use it instead -- another poster has already linked you to that ...
So I don't know what your problem is. On a Mac, use the BloggieUnwarpVideo zip file. The instructions are simple, and the process is much better than the software Sony supplies. You can choose a higher quality output codec (I use ProRes), you can chose a larger dimension output file (I up sample by 50%), and you can quickly preview -- truly, better in every way.
But for some reason your post indicates you haven't found or can't figure out the solution you've been pointed to ..?
Cheers,
GB
asiavr
by asiavr » Sat Sep 17, 2011 1:03 pm
hi guys
i have a question regarding the bloggie too.
i hacked my bloggie also by removing one of a magnet inside the dome head so that all dome video can be recorded at 1080 30f rates.
but when i want to convert the video file in pmp, it says the file format is not support?
is it a limitation for the pmp software?
many thanks
vklaffehn
by vklaffehn » Sat Sep 17, 2011 4:33 pm
Yes, if you have removed the magnet, the only way to unwrap the video is third party software, it will work with the software provided under the link above.
MfG
V.Klaffehn
asiavr
by asiavr » Sun Sep 18, 2011 9:46 am
hi
thanks for your reply.:)
would you mind if u can tell me a little more how to use the unwrap software?
1. i download this 20mb software and unzip it in my pc
http://www.flong.com/blog/wp-content/uploads/2010/06/BloggieVideoUnwarp.zip
2. then i download the processing environment software and also unzip it in my pc
http://www.processing.org/download/
3. execute the processing environment software
4. i suppose i need to open the bloggie unwrap.pde file in the program.
5. after that ,,, what should i do next? how can i unwrap my dome videos here?
vklaffehn wrote:Yes, if you have removed the magnet, the only way to unwrap the video is third party software, it will work with the software provided under the link above.
MfG
V.Klaffehn
vklaffehn
by vklaffehn » Sun Sep 18, 2011 10:28 am
Are you on a PC or a Mac? I'm a PC user and used the following on Ubuntu Linux :
mplayer -vo jpeg:optimize=100:quality=100:outdir=/home/me/Panorama/bloggie/1080 '/home/me/Panorama/bloggie/bloggie-360Lens(1080-30p)-1.mp4' -nosound
cd /home/me/Panorama/bloggie/1080
 ls *.jpg | xargs  -I FILE convert  FILE  +distort DePolar '686 176 938,531' /home/me/Panorama/bloggie/square/FILE
cd /home/me/Panorama/bloggie/square
 mencoder mf://*.jpg -mf w=1603:h=510:fps=30:type=jpg -of lavf -ffourcc FLV1 -ovc lavc -lavcopts vcodec=flv -o '/home/me/Panorama/bloggie/bloggie-360Lens(1080-30p)-1_unwraped.avi'
mplayer -vc dummy -vo null -ao pcm:file=/home/me/Panorama/bloggie/audio.wav '/home/me/Panorama/bloggie/bloggie-360Lens(1080-30p)-1.mp4'
mencoder -audiofile /home/me/Panorama/bloggie/audio.wav -oac mp3lame -ovc copy '/home/me/Panorama/bloggie/bloggie-360Lens(1080-30p)-1_unwraped.avi' -o '/home/me/Panorama/bloggie/bloggie-360Lens(1080-30p)-1_unwraped_with_audio.avi'
HansKeesom
by HansKeesom » Sun Sep 18, 2011 10:58 am
see if you can download from http://www.0-360.com/software.asp they have a mac version. It is strictly forbidden to use it for other things then their own stuff so be warned....
Regards, Hans Keesom
asiavr
by asiavr » Mon Sep 19, 2011 8:13 am
i m pc user.
do you mean i need to install and boot up linux in order to use the unwrap software?
i do not have much knowledge on linux os
regards
vklaffehn wrote:Are you on a PC or a Mac? I'm a PC user and used the following on Ubuntu Linux :
vklaffehn
by vklaffehn » Mon Sep 19, 2011 10:26 am
you can try an ubuntu live CD, its not that difficult, dont need to be a linux professional:-)
