Embed all data
Acmj
Embed all data
by Acmj » Mon May 23, 2011 10:00 pm
After I make the tour, I want to edit xml files OK. After I edited, How can I transform to One swf file.
In Krpano I have Kr protect, and with Panotour pro What I have to do?
Thank you
jazzmessenger8
by jazzmessenger8 » Tue May 24, 2011 7:10 am
How do you edit the xml files? How do you gain access to the code?
Likes: 14 posts
by bdd » Tue May 24, 2011 7:27 am
You can embed modified XMLs into the generated swf by using the "Use existing XML files" feature in the "Project Properties/Tour Build" tab :
http://www.autopano.net/wiki-en/action/view/Panotour_Pro_1.5_-_Project_Properties_-_Tour_Build
by mediavets » Tue May 24, 2011 10:04 am
jazzmessenger8 wrote:How do you edit the xml files? How do you gain access to the code?
You need to use Panotour Pro (you cannot do it with Panotour) then uncheck the 'Embed XML files' option in the Tour Build tab of Project Properties - screenshot 1.
You can then find the XML files created bt PTP using the Edit/Open last exported project directory menu - screenshot 2.
Acmj
by Acmj » Mon Aug 22, 2011 12:12 pm
But Please I want change something on xml file and what I have this message ( The project should not be changed between the last export of XML files and the use of this option)
If I do this is for change OK . And What I have to do to get one swf again?
thank you
Likes: 14 posts
by bdd » Mon Aug 22, 2011 3:09 pm
The message "The project should not be changed between the last export of XML files and the use of this option" is a warning message that is displayed when you click on the "Use existing XML file" checkbox and if you modified your tour with Panotour Pro between the last build and the new one.
It is displayed to warn you that something you just made in PanotourPro will not be in the tour that will be built, because Panotour will not generate new XML files, but will use the one generated previously.
If you did not modify any parameter in PanotourPro, you should not have this message.
