hotspot default
rbackhaus
hotspot default
by rbackhaus » Fri Apr 22, 2011 3:07 am
hi all,
Can I change the default hotspot somehow,...currently it is nuetral in the menu,....can I change that somehow, somewhere so I dont have to keep manually changing for each hotspot when Im using something other than the default??
Rob
by mediavets » Fri Apr 22, 2011 5:51 am
Are you using one of the standard built-in themes?
Are you using Panotour Pro?
If so, then use the Edit/Open Templates Directory command to find the main XML file for your preferred theme in the Themes folder/dircetory - for example 2D.xml - open it with a text editor and find and modify the section shown in the screenshot to change the default hotspot type:
rbackhaus
by rbackhaus » Mon Apr 25, 2011 4:11 am
thanks again media,....is there someplace where I can set the hotspot transition default
