publishing
PeterPandi
publishing
by PeterPandi » Thu Apr 07, 2011 4:34 pm
hi,
I want to publish the tour i am working on to show it to you but i publish the swf file and i get this error.which files i have to publish and where?
http://manuelterra.com/page2/assets/El%20Libro%20Oriental.swf
thx again
by klausesser » Thu Apr 07, 2011 4:51 pm
PeterPandi wrote:hi,
thx again
You have to put ALL content including an index.html on the server into the same folder and link to the folder. If you have it on the server without a dedicated folder you nevertheless must have it ALL together on your webspace.
The error-message says you didn´t do so.
by mediavets » Thu Apr 07, 2011 5:23 pm
thx again
The simplest way to ensure tha you upload all the necessary files is always to output each tour to a new folder. Then upload all the files PTP creates in that output folder to your Web server, maintaining the folder/file structure.
To minimise potential problems I recommend that you avoid accented characters and mixed case in file and folder/directory names, and also avoid spaces in file and folder/directory names.
PeterPandi
by PeterPandi » Fri Apr 08, 2011 8:24 am
okay assume ALL means ALL including the panos which are quite heavy 5 pictures hdrs tiffs, so ill jpeg them.regards
by mediavets » Fri Apr 08, 2011 8:44 am
PeterPandi wrote:okay assume ALL means ALL including the panos which are quite heavy 5 pictures hdrs tiffs, so ill jpeg them.regards
No, no, no...
You don't include the original pano images.
As I said export the tour to a new folder - not the folder containing the input images.
Do this using the Build tour as... option and create the new folder into which you save the tour before the first build of the tour.
PeterPandi
by PeterPandi » Fri Apr 08, 2011 9:28 am
I am doing that right now, I assumed that it would be worth doing it for testing if it worked.made a new folder and built a tour as, just as you said.thx!
