Krpano E card plug in
360photography
by 360photography » Wed Apr 06, 2011 1:32 pm
Any way we can integrate the krpano ecard plugin? i am not good with manually editing the code etc. Was wondering if there is a easy way to ad it or if someone can give me some advice on how to ad it manually to my tours.
by mediavets » Wed Apr 06, 2011 1:34 pm
360photography wrote:Any way we can integrate the krpano ecard plugin? i am not good with manually editing the code etc. Was wondering if there is a easy way to ad it or if someone can give me some advice on how to ad it manually to my tours.
Where do I find the ecard plug-in?
by klausesser » Wed Apr 06, 2011 1:35 pm
Afaik you can buy the plugin from "Iceman" in the krpano-forum. should be easy to implement - i guess . . :cool:
by mediavets » Wed Apr 06, 2011 1:40 pm
I found it:
http://krpano.com/plugins/userplugins/ecard/
360photography
by 360photography » Wed Apr 06, 2011 1:44 pm
I bought the plug in and they have sent me everything. But i have no idea of how to implement it. Should i edit the code myself or can i someone bring the plug in into ptp
