Pictures
PeterPandi
Pictures
by PeterPandi » Mon Apr 04, 2011 2:00 pm
I want to make a hotspot to take me to a picture, that is easy.I wonder if I can place contrls in that jpeg picture with +and- symbols to encrease or decrease size during viewing.thx
by mediavets » Mon Apr 04, 2011 2:26 pm
PeterPandi wrote:Hi,
I want to make a hotspot to take me to a picture, that is easy.I wonder if I can place controls in that jpeg picture with +and- symbols to encrease or decrease size during viewing.thx
Not via the PTP GUI - I guess you may be able to do something like that by hand coding support for a Flash-based image viewer/gallery.
I thiunk you may find something about that on the krpano foprum - search for 'simple viewer'.
Butr that would olnl work for playback on Flash-enabled platforrms and wouldn't work when viewing on iDevices if you select 'mobile-compatible' output.
