Google Maps
360photography
Google Maps
by 360photography » Mon Apr 04, 2011 7:44 am
Is there anyway to use Google maps witin Autopano pro tours. I have the Google maps plugin from Krpano. Is there anyway to intergrate that or how can i procede with this>?
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Apr 04, 2011 9:10 am
For now you have to add Google Maps plugin by hand after tour has been generated by Panotour Pro (and be sure you don't put the tick to embed everything as you need to edit XML files generated by Panotour Pro) !
Vincèn
Blog: http://www.skivr.com
by gkaefer » Mon Apr 04, 2011 10:03 am
Alexandre did mention the Google Maps implementation into Panotour in following reply to my posting:
http://www.autopano.net/forum/p76944-2011-02-10-14-27-08#p76944
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Apr 04, 2011 10:07 am
gkaefer wrote:Alexandre did mention the Google Maps implementation into Panotour in following reply to my posting:
Yep but it's not yet avalaible and it won't use Google Maps KRPano Plugin but one developed by Kolor if I understood correctly ;)
Vincèn
