croping a 180 panorama
PeterPandi
by PeterPandi » Sun Apr 03, 2011 11:14 pm
hi,
I need to crop a 180 degree panorama, the crop tool seems to work only in the bottom and top not on the sides.what can i do?
thx
by mediavets » Sun Apr 03, 2011 11:38 pm
PeterPandi wrote:hi,
thx
If a pano image has a HFOV of 360 degrees then PTP won't let you crop on the horizontal dimension.
Does you image have a HFOV of 360 degrees?
If it doesn't then enter the correct values for Panorama properties/Projection before attempting to crop.
If it does have a HFOV of 360 and you wish to crop on the horizontal dimension then manually change the HFOV to 359 before cropping.
PeterPandi
by PeterPandi » Mon Apr 04, 2011 10:16 am
thx, learned
