How can i . . .
How can i . . .
by klausesser » Wed Mar 30, 2011 6:54 pm
. . . tell PTP to build tablet faces of 2048 instead of 1024px?
by mediavets » Wed Mar 30, 2011 7:12 pm
klausesser wrote:. . . tell PTP to build tablet faces of 2048 instead of 1024px?
Are you selecting 'mobile compatibility' when exporting/building your tour?
by klausesser » Wed Mar 30, 2011 7:31 pm
mediavets wrote:Are you selecting 'mobile compatibility' when exporting/building your tour?
Yes - of course, ;).
PTP creates tablet-faces of 1024px. That´s too small for us - we want them to be at least 2048px for a slightly better zooming on iPad. It works fine to make it using the KRPano-tools - here i can edit the config file and set tablet-faces to 2048px.
I would like to use PTP for that so i have to edit the tabletface settings. I could manually edit the tablet faces - do new ones manually and replace the existent ones - but that´s very uncomfortable.
