Zoom on iPad limited - on computer it´s normal
by klausesser » Tue Feb 01, 2011 11:08 pm
Hi!
I uploaded a 3,4GPx sphere now - the reason is a deep zoom. On my Mac it works fine - on the iPad/Phone i can zoom in just a little bit.
I limited the vertical angle in the XML - but i let PTP made it a sphere because of iDevice compatibility.
http://www.klausesserstudio.com iPad and "normal".
Here´s the part of XML which deals the zoom and angles:
<panoview h="30.25" v="0.09" fov="90"/>
<!-- view parameters -->
<view fisheye="0" limitview="range" hlookatmin="-180" hlookatmax="180" vlookatmin="-55" vlookatmax="55" maxpixelzoom="1.0" fovmax="90" fov="90" hlookat="10.25" vlookat="0.09"/>
<progress showload="none" showwait="none"/>
<autorotate horizon="0.09" tofov="90"/>
<!-- preview image -->
Any idea somebody? :cool:
I checked some of the "view" parameters in the xml - but i guess they´re working different on iPad version. With the "normal" version they work fine.
rbackhaus
by rbackhaus » Wed Feb 02, 2011 5:42 am
Klaus,
the i pad versions will be limited due to the memory capacity, they use the ipad and tablet images(tiles) it initially created for your xml, and are limited to those
by klausesser » Wed Feb 02, 2011 11:59 am
rbackhaus wrote:Klaus,
Hi!
Yep - i read on the KRPano-site that multires is not working on iPad/Phone . . . hope they´re working on it :cool:
