how to make . . .
how to make . . .
by klausesser » Sun Jan 30, 2011 1:11 am
. . . a 80000x40000 equirectangular work as a sphere with a deep zoom? Guess PTP wouldn´t do it.
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jan 30, 2011 7:41 am
PTP is supposed to be able to mamnage gigapixel panoramas so it should do it ;)
Blog: http://www.skivr.com
by klausesser » Sun Jan 30, 2011 2:40 pm
vincen wrote:PTP is supposed to be able to mamnage gigapixel panoramas so it should do it ;)
A .psb file of about 7 GB? I´ll give it a try!
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jan 30, 2011 4:24 pm
Well for sure it can handle PSB of 4Gb which is largest I currently use in one of my virtual tour :) It's just long time to open project :/
Vincèn
by klausesser » Sun Jan 30, 2011 5:04 pm
Now - PTP took my 7GB image. It made a working pano. I uploaded it to my server - but the result is:
www.360impressions.de/Hafen/Hafen85.html
I added all license files to the "Hafen"-folder on my server . .
I activated "restricted domain" because it reads that only then several features work . . whatever that means - not documented as usual . .
Now i will render again without activating restricted domain and i hope it will work . .
by klausesser » Sun Jan 30, 2011 5:29 pm
Great!! Now i rendered again without having "restricted domain" checked - look here: http://www.360impressions.de/Hafen/Hafen85.html
I´m wasting too much time with that - makes me crazy . . . think about looking for a better structured and documented application.
by klausesser » Sun Jan 30, 2011 5:48 pm
here´s a screenshot of the licens-files on the server:
by mediavets » Sun Jan 30, 2011 6:31 pm
If you create tours with PTP then as far as I know there's no need to upload your krpano licence files because the relevant licesing in built-in with PTP; PTP users in future won't even have those krpano licence files..
When I access that URL - http://www.360impressions.de/Hafen/Hafen85.html - I get a 404 so did you upload that HTML file?
by klausesser » Sun Jan 30, 2011 6:42 pm
mediavets wrote:If you create tours with PTP then as far as I know there's no need to upload your krpano licence files because the relevant licesing in built-in with PTP; PTP users in future won't even have those krpano licence files..
Hi Andrew!
I´m uploading completely new - 249MB. Cause i did a version without having "restricted domain" activated. Hope it works though. At "restricted domain" is written that it´s to be essential for having "advanced javascript functionalities" (dynamic XML loading, interaction with panorama datas, . . .)
WHATEVER THAT MIGHT MEAN . . . :rolleyes::cool:
I hope the pano works without that . . will take some time to load up . . coming from another machine.
best to you, Klaus
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jan 30, 2011 7:21 pm
You don't need to activate "restricted domain" feature to be able to enjoy all capabilities of PTP ! and in all matters as told by mediavets you don't need to upload your krpano licences ! PTP generates a whole virtual tour complete you just need to upload to your server and that's it :) In fact it embeds the licences files in the swf of krpano ;)
Vincèn
by klausesser » Sun Jan 30, 2011 8:50 pm
vincen wrote:You don't need to activate "restricted domain" feature to be able to enjoy all capabilities of PTP ! and in all matters as told by mediavets you don't need to upload your krpano licences ! PTP generates a whole virtual tour complete you just need to upload to your server and that's it :) In fact it embeds the licences files in the swf of krpano ;)
Vincèn
Thx, Vincènt!
I uploaded now and it works fine - it´s just a test. What do the restricted domain add-ons mean? Special hidden features? Sinister scriptings? :cool:
What´s the sense of "restricted domains" anyway?
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jan 30, 2011 9:08 pm
klausesser wrote:What do the restricted domain add-ons mean? Special hidden features? Sinister scriptings? :cool:
Restricted domain allows you to list one or more domain names on which virtual tours might be play ! If someone tries to load virtual tour on a different domain it won't run ! It might help to avoid steal of virtual tour or customer that reuse your virtual tour for something else !
Vincèn
by klausesser » Sun Jan 30, 2011 9:20 pm
vincen wrote:Restricted domain allows you to list one or more domain names on which virtual tours might be play ! If someone tries to load virtual tour on a different domain it won't run ! It might help to avoid steal of virtual tour or customer that reuse your virtual tour for something else !
That´s what i thought it to do also. But what about the "advanced javasript features"? Does something refuse to work if the domain is NOT restricted?
by mediavets » Sun Jan 30, 2011 9:42 pm
klausesser wrote:But what about the "advanced javasript features"?
I've always assumed this relates to:
http://krpano.com/docu/js/
by klausesser » Sun Jan 30, 2011 9:50 pm
mediavets wrote:I've always assumed this relates to:
That´s extremely enlighting as always with KRPano . . . :P:cool: Thank you, Andrew!
Well - it finally works now . . that was just a test for a new project, didn´t optimize at all.
