HELP please about button language options
Neyo
by Neyo » Mon Jan 24, 2011 12:08 am
Hi to everyone,
I am new in your forum and after I bought the panotour pro software I decided to read your posts before ask to you, but unfortunately (in search option) I no found any info about my doubt.
I ask to you how I can create two buttons language before to open a virtual tour.
I desire to create this pano.
http://www.torun.pl/spacer/
When I click on a link/virtual, I want to see a video in gray color with inside two buttons language. One in english and one in japanese.
How I can to do it? How I can create the button with one language.
I don't think I must to download to my client two series of panorama with embeded language, I don't think , in this way it will be an heavy project.
I think it's possible to build one serier of virtual tour , but I don't know as I can to choise the language in the beginner
I hope you understand my question as I hope you will hep me in this post.
Many thanks in advance to all will answer me.
by mediavets » Mon Jan 24, 2011 6:35 am
Welcome to the forum...
Do you have Panotour or Panotour Pro?
asafmordechai
by asafmordechai » Mon Jan 24, 2011 7:18 am
nice idea.
I would like to now too Hebrew/English.
I have Panotour Pro.
Neyo
by Neyo » Tue Jan 25, 2011 2:30 pm
mediavets wrote:Welcome to the forum...
I have Panotour Pro, do you think can help me? I hope.
by mediavets » Wed Jan 26, 2011 8:04 am
If you have Panotour Pro that means you can externalise the XML and I expect with some clever coding (and perhaps some Javascipt) you could effect some 'language-sensitive switching'. If you what to attempt this then it's probably best to seek guiidance on the krpano forum:
http://krpano.com/forum/wbb/index.php?l=2
But I feel that it would be far simpler just to create two versions of the tour - one in/for each language; and then some simple preamble/preview (a simple third tour perhaps?) that offered the user a choice of language options to switch thereafter to one language variant or the other other.
Neyo
by Neyo » Wed Jan 26, 2011 9:19 am
mediavets wrote:If you have Panotour Pro that means you can externalise the XML and I expect with some clever coding (and perhaps some Javascipt) you could effect some 'language-sensitive switching'. If you what to attempt this then it's probably best to seek guiidance on the krpano forum:
Do you think it's impossible to create a pano as the link? As you note , you can see the first "page" and you can choise the language. How I can add this first page?
by mediavets » Wed Jan 26, 2011 10:18 am
Neyo wrote:Do you think it's impossible to create a pano as the link? As you note , you can see the first "page" and you can choise the language. How I can add this first page?
I'm confused.
Are you saying you want to create something like this? Or are you saying this is what you have created but you want it to be different in some way?
Neyo
by Neyo » Wed Jan 26, 2011 2:51 pm
I'm confused.
I am saying, I want to create something like this. I desire to put a mask before open the virtual and in this mask I will put the buttons/language. After I push the button/lunguage I prefer, than the virtual will open with the language preferred.
It's possible to do it?
Thanks.
by mediavets » Wed Jan 26, 2011 8:02 pm
Neyo wrote:I am saying, I want to create something like this. I desire to put a mask before open the virtual and in this mask I will put the buttons/language. After I push the button/lunguage I prefer, than the virtual will open with the language preferred.
Thanks.
The whole tour is very impressive with many advanced features, but I think just creating a way to select between two different language versions of a tour should be relatively easy.
Basically:
1. Create a separate tour for each language variant; and export each to a separate folder.
2. Create a third tour with just one 'pano' - this is the pano/page from which you select from the availbale language variants. Create a hotspot with a custom graphic for each language option and link each to the URL for appropriate tour. You'll need to use the URL of the tour as it will be when on-line.
Each of the 3 tours will need to be in separate folder/directory to avoid filename conflicts and accidental overwriting of files.
What do you think?
Neyo
by Neyo » Thu Jan 27, 2011 3:30 am
Yeah maybe it would be a solution , but if I do 3 tours, it's means I will delivery 3 folders too heavy even if at today I no understood if I must delivery all folders that create Panotour Pro. In the past I delivered with Pano2Vr only 2 files, one html and one swf. Now I understood the folders with cubes are important, but I don't know exactly what I must delivery to my clients. Also I think to delivery all folders, it will be dangerous because someone can "touch" some files and all panos linked will not works. So, at last, turning to the language, maybe I think there is another solution, but please help me to find it. My idea is: it's possible to put two buttons inside the pano and putting the pictures with the flags people will decide the language with two different voices. I explain you better. People enter inside tour and then can decide (pushing the buttons) if desire to hear one or other language. It would be a solutions?? One tour , two voice/language.
Thanks again
by mediavets » Thu Jan 27, 2011 5:33 am
Neyo wrote:So, at last, turning to the language, maybe I think there is another solution, but please help me to find it. My idea is: it's possible to put two buttons inside the pano and putting the pictures with the flags people will decide the language with two different voices. I explain you better. People enter inside tour and then can decide (pushing the buttons) if desire to hear one or other language. It would be a solutions?? One tour , two voice/language.
Thanks again
Then you'll have to do it with custom coding.
I did a quick search of the krpano forum and found this, it may be relevant:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=457&highlight=languages
Neyo
by Neyo » Fri Jan 28, 2011 9:42 pm
Thanks again
Hi, I have read in the forum krpano , they use to put an intro screen that include two buttons languages (before to enter in the virtual). My question is: can I add an intro screen with Panotour Pro, because I don't have KrPano . Thanks again.
Neyo
by Neyo » Sat Jan 29, 2011 7:34 pm
Neyo wrote:
Thanks again
Please someone can give some suggestions about buttons/language to add into a intro screen before the virtual.
How I can do it.
Neyo
by Neyo » Thu Feb 03, 2011 2:20 am
How I can do it.
