the music wont continue after playing a movie & more
asafmordechai
by asafmordechai » Sun Jan 23, 2011 3:10 pm
hello.
using RC 2 here a link to a project that is still in progress.
http://www.photo-man.co.il/apage/86571.php
1. the movie is playing in repeat mode - how do i stop it, i wont it only to play once.
2. after I stop the movie the music won't resume ... why ?
3.if pressing on the go-cart the movie will play:
why there is triangle only on one ? all 3 of them are Hotpoint ?
asafmordechai
by asafmordechai » Thu Jan 27, 2011 4:39 pm
there is no solution ?
I tried in RC 3 the same results.
by mediavets » Thu Jan 27, 2011 4:43 pm
Does it work as you wish when played back locally?
asafmordechai
by asafmordechai » Fri Jan 28, 2011 7:10 am
No.
there is a repeat option in the program, i entered 99.
by mediavets » Fri Jan 28, 2011 7:48 am
asafmordechai wrote:No.
Why did you enter 99 if you want to play only once?
asafmordechai
by asafmordechai » Fri Jan 28, 2011 10:09 am
I think you misunderstand me.
on the 2ed image :
1. make the song play after it ends again.
2. hot spot to the video ... after the video ends 2 problems :
A. it start again, and I wont it to play only once.
B. if I end it the music of the tour wont continue.
* I tried to make the clip with out sound of music ( but with the engine sound) it didn't make any different.
* I tried whit no sound in the clip at all, but the same results.
C. why only one hot spot (go cart) as triangle on it and the 2ed two don't ?
3. link to the web page - the music continue ...
one more problem, for some reason the tour don't work on iPhone 4. (the 1st image)
Last edited by asafmordechai on Fri Jan 28, 2011 10:41 am, edited 1 time in total.
by mediavets » Fri Jan 28, 2011 2:58 pm
asafmordechai wrote:one more problem, for some reason the tour don't work on iPhone 4. (the 1st image)
Some comments:
1. All panos in the tour must have 360x180 pano FOV.
2. You need to use the generic HTML template and access the tour by that means to ensure the script directs/delivers the correct compatible content to iDevices.
3. I'm not all sure that sound and video in tours are (yet) compatible with iDevices - iDevices have limited computer power and memory so can easily be 'swamped' with large files.
asafmordechai
by asafmordechai » Sun Jan 30, 2011 7:01 am
lets ignore for now from problem No 4 iPhone issue.
what about the 1-3 can they be resolved ?
