controls bar buttons size
jimenezcano
by jimenezcano » Sat Jan 08, 2011 1:02 am
How could I change the size of the buttons in the navigation controls bar in Pano Tour Pro?
I´d like to have them smaller.
Thanks,
micha22
by micha22 » Sat Jan 08, 2011 9:54 pm
go to Project Properties -- Appearance and here Margin. With the number you can build bigger or smaller buttons, but you see the changeit only in the rendered panorama.
Best michael
jimenezcano
by jimenezcano » Sun Jan 09, 2011 3:15 am
Hello Michael,
I tried what you told me but the number in margin actually changes the position of the controls bar but not the size.
The grater the number the farther position from the bottom.
Should I try in another way?
micha22
by micha22 » Sun Jan 09, 2011 1:28 pm
sorry i give you the wrong information :/
When you generate the tour without embeding the xml-files you can change the size of the buttons in the first xml named same with your project.
Open the xml for example with notepad, go to menue, here you see the plugins for the buttons.
For example the zoom in button:
<plugin name="in" align="bottom" crop="0|0|65|65" height="prop" keep="true" ondown="set(fov_moveforce,-1);" onout="" onover="" onovercrop="0|65|65|65" onup="set(fov_moveforce,0);" url="testbuttondata/graphics/menu/menu0.png" width=" CHANGE THIS NUMBER TO SCALE THE BUTTON " x="-180" y="8"/>
Now you can if nessecary change the position of the buttons with the x and y number.
I have test it, it will work.
If you want, put all the files together with Kprotect.
Best Michael
by mediavets » Sun Jan 09, 2011 3:50 pm
jimenezcano wrote:Hello,
Thanks,
You could create your own theme with modifed versions of the stnadard teme button images, or you could create your own button images.
If you would prefer to purchase button images you may find something suitable here:
http://skins.360panotours.com/
http://skins.360panotours.com/animations.html
jimenezcano
by jimenezcano » Sun Jan 09, 2011 6:41 pm
Thank you very much Michael,
you helped me a lot, it worked!
Thanks mediavets for the info about modified versions of the buttons
Regards,
micha22
by micha22 » Sun Jan 09, 2011 9:28 pm
Nice to help you!
I`ve learned so much from this forum, so i try to give back some tipps.
Best michael
