Please I need help. How can I use existing XML files to interaction with my panorama on Panotour Pro V1.5.0 rc2? and what can I do with restricted web domains and how I have to use it? Can somebody help me?
But, I Ask you, if I want to put for example Snow. Hom can I make the tour on Panotour pro and put this xml together. On Krpano I dont have problem to make a code, but I want make a tour with my autopano pro and add more xml file or edit the xml files from Panotour pro. Thank you
hmm.... PTP Pro 1.5 RC3... Project Properties->Tour Build-> disable "Embed all data" and "Embed XML files" so you get html and seperate xml files. These xml files can be edited later and so xml code coming from krpano could be integrated (manually)
so this extends the possible features but also dramatically makes any update of an existing tour difficult...
