Import cube faces
Marv
Import cube faces
by Marv » Thu Jan 06, 2011 2:51 am
In V1.5.0 RC2 File/Add Panorama I see there is a add cube faces for import and export. What are these for?
I ask because sometimes I need to edit the cube faces... and sometimes go back and make a new pano.
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
by mediavets » Thu Jan 06, 2011 7:06 am
Marv wrote:In V1.5.0 RC2 File/Add Panorama I see there is a add cube faces for import and export. What are these for?
Export cube faces/Import cube faces provide a two-way equirectangular to cube face conversion facility; which is what you appear to need sometimes so you can edit cube faces. Export generates cube faces from an equirectangular image and Import converts cube faces into an equirectangular image.
Marv
by Marv » Thu Jan 06, 2011 6:22 pm
Thanks Andrew. That's exactly what I need sometimes to fix things.
Also... this may solve a project where I want to add objects to a Pano after it's shot.
Great feature.
Marv...
