Remplacer panorama dans projet sans tout refaire
andebu
by andebu » Tue Dec 21, 2010 10:27 am
Je souhaiterais connaitre la procédure pour remplacer dans un projet un panorama affecté de quelques défauts, par la même image corrigée, sans avoir à  reconstruire tous mes liens (hotspots).
J'exporte sans incorporer les données et sans incorporer les fichiers xml.
J'utilise Panotour pro 1.5.0 RC.
Je vous remercie
Patrice
Canon EOS 7 D, Samyang 8 mm f 3.5, MANFROTTO 055XPROB, Nodal ninja NN 3 II
by mediavets » Tue Dec 21, 2010 11:11 am
Did you save the project?
If so, then I can't see why this won't work....just replace the original pano file in the same location and with the same name with your revised file - open the project and export the tour.
If you use the 'Save project (extended) as...' command when saving the project then all source files are copied to a folder/directory which makes this sort of thing easier later because you won't have to remember where the various source files were located.
andebu
by andebu » Tue Dec 21, 2010 11:29 am
Hi Andrew
Thanks for your help
I have now saved my project with the command you proposed me ( 'Save project (extended) as...') and now I can locate the source files used in my project. It's easy now to replace the modified file.
Thanks again
Best regards
Patrice
