Snow effect
davemack
Snow effect
by davemack » Wed Dec 01, 2010 9:36 pm
Hi, is there any way I can add the 'snow effect' that KRPano supplied as a swf file to PanotourPro? (i'm not any good at HTML coding)
by mediavets » Wed Dec 01, 2010 11:12 pm
davemack wrote:Hi, is there any way I can add the 'snow effect' that KRPano supplied as a swf file to PanotourPro? (i'm not any good at HTML coding)
You'll find clues here - you will have to edit the XML generated by Panotour Pro:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=129&pageNo=2&s=cdf811bda45910d4a9e34c8f2ea0386d90d2a428
