How can i fix the incorrect behaviour of the tumbnails in panotour pro
micha22
by micha22 » Tue Nov 23, 2010 12:29 am
have anybody an idea what to do to swoh the tumnails correctly?
Best michael
digipano
by digipano » Tue Nov 23, 2010 3:02 am
You need to set the correct parameters in pixel or percent. What kind of problem are you facing?
micha22
by micha22 » Tue Nov 23, 2010 11:36 pm
My Problem was the incorrect display of the thumbnails on the darkgrey slider.
I have solved the problem with setting the transparency of the slider to maximum.
Have a look http://www.schellinger-fotografie.de/iPhone/Schoettlehotspot/SchoettlePanotourpro.html.
now it works, my provider had a problem.
Best Micha
Thank you!
Best Micha
