Tiles and Cutting Size...
marco.lanciani
by marco.lanciani » Mon Nov 22, 2010 8:08 pm
A few questions.
- How "cutting size" affect the final panorama?
- What's the practical difference on using 512 or 256 or 128 or 64...
A D7000 is on my plans... What about a full resolution panorama at 16000x8000 or more, using the 10.5mm, to give the client more zooming in?
- What would be the appropriate cutting size?
- Why?
As for the krpanotools droplets:
- can I input the cutting size parameter?
- can I change jpeg compression of the autogenerated tiles of a multires pano?
- what's the difference between "MAKE PANO (TILED)" and "MAKE PANO (MULTIRES)"
Thanks,
Marco
digipano
by digipano » Tue Nov 23, 2010 3:18 am
cutting size cuts the pano images into smaller tiles for (multires panos only) so if a user is looking for a specif area of 128 by128 pix then the tile of that area will be downloaded from the server.
as per above example the specific area tile needs to be downloaded & if the user is viewing the area of 128x128 pix & your tiles are 512 pix it will have to be downloaded a much bigger tile which maybe not user friendly to the bandwidth, so smaller tiles will render tours faster when fully zoomed in.
Yes you can change the various parameters in kmakemultires.config file, open the file in text editor & ensure you save it as .config file not as text file.
they both are self explanatory, make pano will create only 6 cubes with limited resolution whereas make pano multires will tile & cut those tiles (1024-64) & make multres tour.
Smaller the tiles such as 64x64 faster tour rendering will happen on slower connection of gigapixel images.
marco.lanciani
by marco.lanciani » Tue Nov 23, 2010 1:04 pm
digipano wrote:
Marco Lanciani wrote:What's the practical difference on using 512 or 256 or 128 or 64...
So viewing in fullscreen resolution, using tiles bigger than 1024 seems useless.
- Am I wrong?
digipano wrote:
Marco Lanciani wrote:"MAKE PANO (TILED)" and "MAKE PANO (MULTIRES)"
Actually I guessed the answer but wasn't sure: tile is not equal to cube face. :)
Thank you very much,
Marco
ygilquin
by ygilquin » Tue Nov 23, 2010 1:28 pm
digipano wrote:Smaller the tiles such as 64x64 faster tour rendering will happen on slower connection of gigapixel images.
This is true, but...
marco.lanciani wrote:So viewing in fullscreen resolution, using tiles bigger than 1024 seems useless.
This is false. Be aware that Krpano player allocates some memory overhead (RAM) for each tile it loads. This means limiting tiles number is a way to reduce memory consumption used by the browser and in certain cases, it's a way to prevent him from crashing. To limit tiles number, you can increase tile cutting size to 1024 for example. Using a high cutting size is recommended for gigapixels tours.
Yann G.
www.kolor.com
marco.lanciani
by marco.lanciani » Tue Nov 23, 2010 2:27 pm
Hi ygilquin,
you're right, infact I thought smaller than 1024 but wrote bigger...(maybe because of the zooming in effect) :)
