Where are the html templates gone?
digipano
by digipano » Mon Nov 22, 2010 4:02 pm
Where are the html templates gone in panotour pro 1.5 beta 2?
I only see 1 generic html in the drop down list but that too is not visible when I open the panotour installation folder to customize that generic template.
digipano
by digipano » Mon Nov 22, 2010 4:06 pm
got the answer from this post, Thanks to mediavets
http://www.autopano.net/forum/p73087-today-20-24-05#p73087
Now I have another question, can I simply copy the (my customized) APT templates to panotour template folder or do I need to make the template for panotour again?
rbackhaus
by rbackhaus » Mon Nov 22, 2010 6:52 pm
digi,
I tried dropping it doesn't work. I can drop it but the templates does not show up on any menu, but IS in the templates menu folder. You can rename one of the templates in the editor,,,say "rotation" to you whatever you want. Close down and make sure your change takes effect and the new renamed xml is there. Then open both the xml you want to use and the renamed xml file in an editor and copy and paste your code to your renamed xml. The rotation buttons will still pop up as you build the tour but wont show up in the final build. Also dont forget to drop in your graphics folder and such that your using.
rob
by mediavets » Mon Nov 22, 2010 6:53 pm
digipano wrote:Now I have another question, can I simply copy the (my customized) APT templates to panotour template folder or do I need to make the template for panotour again?
What sort of templates are these you refer to?
Are they HTML templates, or navigation button templates, or some other type of template?
rbackhaus
by rbackhaus » Mon Nov 22, 2010 7:12 pm
I thought he was referring to his own personally constructed/edited xml templates
digipano
by digipano » Mon Nov 22, 2010 7:22 pm
Yes I meant HTML templates with custom color background & some text.
If possible then same for xml templates so I can have various projection mode on right click available instead doing it manually every time.
rbackhaus
by rbackhaus » Mon Nov 22, 2010 8:13 pm
just tried it,...looks like the html folder is more friendly,..looks like you can copy, add, rename and the html file will remain in the drop down html menu
by gkaefer » Tue Nov 23, 2010 9:54 am
... and that the userdefined files show up in the pulldown menu, APT/PTP has to be restarted....
