Autorotation not fluid in fullscreen
marco.lanciani
by marco.lanciani » Sun Nov 21, 2010 8:03 pm
Can someone tell me why I can't have a smooth autorotation movement in fullscreen mode?
Have a look:
http://www.marcolanciani.com/exhibitions/pieri/20101010/vr/
Any solution?
Marco
rbackhaus
by rbackhaus » Sun Nov 21, 2010 11:16 pm
nothing there,.....red x
by klausesser » Mon Nov 22, 2010 9:30 am
marco.lanciani wrote:Can someone tell me why I can't have a smooth autorotation movement in fullscreen mode?
Have a look:
Any solution?
Marco
Hi Marco!
Too big image-data? Wrong cutting-size? Hardware? Hard to say without knowing more . . :cool:
marco.lanciani
by marco.lanciani » Mon Nov 22, 2010 3:57 pm
klausesser wrote:Hi Marco!
Hi Klaus,
have a look at the pictures.
Also, what about using the krpano droplet?
- Can I input the cutting size, jpeg compression...?
- and what's the difference between "MAKE PANO (TILED)" and "MAKE PANO (MULTIRES)"
Maybe, is TILED limited in resolution? The "releasenotes.txt" file doesn't tell.
by gkaefer » Mon Nov 22, 2010 4:16 pm
If I manually look into sourcecode of your entry page I see it tries to load
index.swf
so If I manually open the link I succeed and I do not get the red X
http://www.marcolanciani.com/exhibitions/pieri/20101010/vr/index.swf
AC_AX_RunContent( 'width','100%','height','85%','src','index.swf','allowfullscreen','true' ); //end AC code
this seems not to be the original sourcecode (?) ...
PS: try an absolute external path to the swf file a la http://...../index.swf
Liebe Gruesse,
rbackhaus
by rbackhaus » Mon Nov 22, 2010 6:18 pm
georges link works for me now,...dont have an answer for you though,...it does jump to try and catch up every so often
marco.lanciani
by marco.lanciani » Mon Nov 22, 2010 6:49 pm
rbackhaus wrote:georges link works for me now,...dont have an answer for you though,...it does jump to try and catch up every so often
Hi rbackhaus,
nothing changed online by your first attempt.
gkaefer wrote:If I manually look into sourcecode of your entry page I see it tries to load
index.swf
Liebe Gruesse,
From the original source code I might have changed only that 85%, from the original 100% (maybe 100%, actually I don't remember). Is this what you mean?
Anyway I don't think this have to do with my problem. Jumps are only in fullscreen mode.
Given an hardware up to the task, it might be something related to jpeg compression and dimension of the tiles and accessible memory.
Any suggestion, on this regard, for 12000x6000 panos?
Also I know I can set the memory used on the xml: what do you suggest for this value?
Regards,
Marco
by klausesser » Mon Nov 22, 2010 7:32 pm
Hey Marco!
Try 10000x5000px and 512 for cutting size.
example:
http://www.klausesser.de/360impressions/OrangeCinema/ZuerichBar.html
