I have a problem that when I take a project file and all the files tat connected to him (copy them) and opening them on my laptop I cant open the project file. if I wont to work on him I have to make him again.
1. You create a new folder for each tour and then ensure you have all the source files in the same place by using the 'Save project (extended) as...' function which will copy the various source files into a single source data folder within your tour folder.
2. You copy the tour folder and all its contents (including the project source data folder) to your other PC.
Andrew Stephens Many different Nodal Ninja and Agnos pano heads. Merlin/Panogear mount with Papywizard on Nokia Internet tablets. Nikon D5100 and D40, Sigma 8mm f3.5 FE, Nikon 10.5mm FE, 35mm, 50mm, 18-55mm, 70-210mm. Promote control.
