iPhone/iPad Tour: Hotspots not working?
by klausesser » Sat Nov 06, 2010 1:11 am
macbenutzer wrote:Hope it is clear now?
Hey Peter!
I did that two hours ago - i described it in the other thread.
here´s the url for testing:
http://www.klausesser.de/Pad.html
I used the script Renan postet here. Pastet it
into a new generated "generic.html"
The result is: i can´t move out of a node when i "click" a hotspot - i just goes back to the start-view of the same node.
macbenutzer
by macbenutzer » Sat Nov 06, 2010 1:22 am
When looking into your sourcecode i still can see the "0" causing the error. Delete it and it will work.
wrong: embedpano({target:"panoDIV",swf:"Pad.swf",xml:"Pad0.xml",width:"100%",height:"100%",allowFullScreen:"true"});
good: embedpano({target:"panoDIV",swf:"Pad.swf",xml:"Pad.xml",width:"100%",height:"100%",allowFullScreen:"true"});
Good luck! Peter
MacPro - MacBook - OS X 10.6.2 - D300 - D700 - Fuji S5 - PhaseOne P65+/P30+
8mm/10,5mm/10-20mm/17-35mm/18mm/25mm/85mm/etc. - wired + BT Merlin/Orion
by klausesser » Sat Nov 06, 2010 6:27 pm
macbenutzer wrote:When looking into your sourcecode i still can see the "0" causing the error. Delete it and it will work.
Good luck! Peter
Hi Peter!
Thank you - i´ll have a look at it right now!
by klausesser » Sat Nov 06, 2010 7:46 pm
macbenutzer wrote:Good luck! Peter
Hey Peter!
Works!! Can i use the same procedere to change the generic.html?
It´s: "embedpano({target:"panoDIV",swf:"$(SWF)",xml:"$(FIRST_PANO_XML)",width:"100%",height:"100%",allowFullScreen:"true"});"
Should i erase the "0" so that it is "FIRST_PANO_XML"?
by klausesser » Sat Nov 06, 2010 7:55 pm
Andrew and Peter - again many thanks for helping!!!! :):):):):)
best to you, Klaus
by mediavets » Sat Nov 06, 2010 8:07 pm
Hey Peter!
Just remove this part....
...altogether.
by klausesser » Sat Nov 06, 2010 10:19 pm
mediavets wrote:Just remove this part....
...altogether.
Hi Andrew - where do i find it?
my generated code is:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Virtual Tour generated by Autopano Tour</title>
<meta name="viewport" content="target-densitydpi=device-dpi, width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no"/>
<meta name="apple-mobile-web-app-capable" content="yes"/>
</head>
<body>
<script src="swfobject/swfkrpano.js"></script>
<h1>Project : $(PROJECTNAME)</h1>
<div id="panoDIV" style="height:100%;">
<script>
embedpano({target:"panoDIV",swf:"$(SWF)",width:"100%",height:"100%",allowFullScreen:"true"});
</script>
<noscript>
<div id="tour">
<object width="100%" height="100%">
<embed src="$(SWF)" width="100%" height="100%" allowFullScreen="true">
</embed>
</object>
</div>
</noscript>
</div>
</body>
</html>
Can´t see any "xml: . . . "
That´s the "generic.html" from the "Kolor>>Template>>HTML>>generic.html"
by mediavets » Sat Nov 06, 2010 10:28 pm
...altogether.
In the original generic .html file.
If this is absent from your generic.html file then you have already made the fix.
by klausesser » Sat Nov 06, 2010 10:39 pm
mediavets wrote:In the original generic .html file.
We´ll see whether it works . . :cool:
pu2wxp
by pu2wxp » Fri Nov 12, 2010 8:23 pm
klausesser wrote:
macbenutzer wrote:i know that we are in beta status. but i just wanted to ask because this error was not reported before and with other examples the hotspots are working. mine are not :-( and i would like to know what i should change to make them work.
i used the defalt theme in Panotour beta 2 and checked the litte checkbox "mobile devices" (do remember the correct name of the checkbox). all images are full 360x180.
are there other things to look after?
Ich glaube, Du muàŸt eine "restricted domain" eintragen - am besten Deine Eigene.
Die Jungs kriegen es nicht auf die Reihe, sich vertstà¤ndlich zu artikulieren . . :cool:
Ist ja ´ne alte Kolor-Spezialità¤t . . .:rolleyes:
Mir ist das mit den hotspots auch noch nicht gelungen.
GruàŸ, Klaus
Hi guys,
In english please, if not I can't understand!
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
by klausesser » Sat Nov 13, 2010 3:23 pm
pu2wxp wrote:Hi guys,
Sorry:
I guess you have to set a "restricted domain" entry. Use your own one.
Seems to be hard to write an easy understandable discription . . :P:cool:
I only recently managed to use hotspots on iPhone/Pad/Pod and i´m still testing.
by mediavets » Sat Nov 13, 2010 3:33 pm
Sorry:
I don't think so.
by klausesser » Sat Nov 13, 2010 3:35 pm
Sorry:
I don't think so.
i somewhere read to use "restrictzed domain" entry for some features - will post a screenshot.
here (whatever it means . . )
ygilquin
by ygilquin » Mon Nov 15, 2010 4:38 pm
B is definitely a better solution (to save time) as it will prevent from doing A for each tour that is built.
Yann G.
www.kolor.com
pu2wxp
by pu2wxp » Mon Nov 15, 2010 6:07 pm
...altogether.
<html>
<head>
</head>
<body>
<script>
</script>
<noscript>
<div id="tour">
</embed>
</object>
</div>
</noscript>
</div>
</body>
</html>
I tried using this code, but did not work. HTML generated an error and has not opened the tour. I could not identify what is wrong, comparing the generic-new.html with original generic.html.
So I just deleted in the original generic.html this part of the code {xml: "$ (FIRST_PANO_XML)",}, and the tours are now fully compatible with the iPhone and iPad. Hotspots are working and even the drop-down menu.
Look here: http://www.vistapanoramica.com.br/mobile/osteria/peretti.html
And the news on my blog about the compatibility of the new iPhone and iPad tours here::
http://www.vistapanoramica.com.br/blog/2010/11/12/tour-virtual-agora-totalmente-compativel-com-iphone-e-ipad/
And I have to say! It's realy, realy cooll!
I Can't wait for the new release of Panotour PRo with new Krpano.
Luciano Correa
Vista Panoramica
by klausesser » Mon Nov 15, 2010 6:39 pm
pu2wxp wrote:And I have to say! It's realy, realy cooll!
Hey, Luciano!
Thanks, man! :cool:
Previous
