[APG 2.5 B1] Colour anchor editing is unusable
by mediavets » Sat Sep 18, 2010 4:05 pm
Windows XP/32 SP3.
Colour anchor editing is unusable. The tools are quite unresponsive and most of the time nothing seems to happen when you change an anchor.
renan
by renan » Mon Sep 20, 2010 10:45 am
issue 241 open
renan
by renan » Fri Oct 29, 2010 8:55 am
We reproduce this on a PC where default color parameter ("settings -> Panorama -> Color correction") was not well set.
If this is the same case, open the settings, choose a valid correction in the combobox "What should be corrected" and restart the application.
pu2wxp
by pu2wxp » Fri Oct 29, 2010 12:12 pm
mediavets wrote:Windows XP/32 SP3.
Simply, I give up trying to use the new tool gama, exposure, color correction. I have to make the import of papywizard XML and photos on Autopano 2.5 and then save and close the program. In the following section I open the program Autopano 1.42 to change the anchor to get ALL MONOTRANSFER to fix the image. :-(
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
by GURL » Fri Oct 29, 2010 1:14 pm
Settings matter (see screen captures.)
The No color correction (NONE) works fine, as far as I know (one should use it when all source images share the same camera exposure and color balance settings)
When using LDR color correction (AUTO) it looks like several yellow pins (fixed anchors) rather than a single one (like in 2.0.x versions) are often needed...
Some indications about using the new Adjust gamma features or not could help ;)
by GURL » Fri Oct 29, 2010 4:14 pm
Gamma and Exposure is buggy...
(Gamma and color tones, Gamma exposure and color tones look fine.)
by GURL » Sat Oct 30, 2010 5:07 pm
J'ai encore fait d'autres essais dans l'espoir de voir ce que donne Adjust Gamma mais y'a trop de bugs (au moins deux à  mon avis), j'abandonne.
Par exemple dans cette série de 9 photos, toute prises avec une différence de 1 EV, la correction à  partir des ancres jaunes se fait parfaitement vers les photos plus sombre mais pas du tout vers les photo plus claires (c'est un exemple artificiellement simplifié, dans les exemples réels on ne comprend rien à  ce qui se passe...)
by AlexandreJ » Tue Nov 02, 2010 11:52 am
I've opened a new issue for GURL reports : issue 390
