[2.5.0 A1] RMS keep changing with optimization
atelescope
by atelescope » Fri Feb 04, 2011 2:16 am
For any .pano file I opened, when I open the control point editor and click either the "Full Optimization" or the "Quick Optimization" button, the RMS will change even if I didn't edit any control point. If I click any of those buttons again, the RMS will change again (along with the stitching). I am wondering if that can be fixed that the RMS will stay at the lowest possible value? Also, this problem appears on saved .pano file only, not any unsaved detected panoramas.
by AlexandreJ » Fri Feb 04, 2011 8:51 am
If the version you are quoting is correct ( Alpha 1 ), I confirm this bug and it's solution : download the Final version here : http://www.kolor.com
