Autopano Engine v2.5 RC2 changelog
by AlexandreJ » Fri Jan 14, 2011 4:02 pm
This is the release candidate too. The main concern was stability and bug fixes. We found some really nasty bugs so this version should better fit as a final release version.
What issue is still open ?
- One concern about blending quality in the multiband. In some case, we can have artifact appearing. We already have a solution candidate but we prefer to take more time on testing before release.
- some small UI bugs that are not blocking the release version
Main changes
- NEW : Reworked update manager with handling of beta version
- NEW : Some translations already integrated
- FIX : Crash when using PSD / PSB output with integrated layer
- FIX : Wrong panorama when reading / writing .pano from old release version, 2.5 beta series
- FIX : 32 bits versus 64 bits version optimization issue ( wrong RMS on 32bits versions )
Fixes
- 0000531: [Editor] CTRL + save all should not display dialog box - resolved.
- 0000496: [Unclassified] Switch NSIS en version unicode - resolved.
- 0000527: [Cortex ( rendu )] Exposure fusion saving / reload is not good - resolved.
- 0000481: [Editor] Make layer editor column value sticky - resolved.
- 0000450: [Editor] Crash àƒ la suppression d'une image quand le CPE est activàƒÂ© - resolved.
- 0000477: [Performance] Linux editor global speed issue - resolved.
- 0000511: [Unclassified] Check script mise àƒ jour - resolved.
- 0000509: [Cortex ( rendu )] pause on batch renderer - resolved.
- 0000508: [Shell Integration] Opensuse cameras.txt report not working - resolved.
- 0000515: [Editor] loading back default focal length - resolved.
- 0000514: [Editor] grid text in white - resolved.
- 0000499: [Cortex ( rendu )] HDR rendering tournette to analyse - resolved.
- 0000504: [Neurone ( optimisation )] Optimization Naples cases : not the same value between 32 and 64 bits - resolved.
- 0000505: [UI behavior] Cannot update image path on Mac when opening .pano made under Windows - resolved.
- 0000483: [Editor] Space bar for checking, unchecking an image in the layer editor - resolved.
- 0000479: [Neurone ( optimisation )] Reading back .pano changes RMS - resolved.
- 0000482: [Editor] Layer edition refresh => you need to scroll down again - resolved.
- 0000487: [Performance] v2.5 versus v2.0.9 drive speed - resolved.
- 0000494: [Performance] Bugsplat disabled - resolved.
- 0000498: [Cortex ( rendu )] Alpha channel in blending mode none is the index of poisson - resolved.
- 0000497: [Cortex ( rendu )] Blend mode is not well saved in .pano - resolved.
- 0000486: [Performance] Rendu harlem 16 bits + layer => crash - resolved.
- 0000478: [translation] Translation issues in NSI - resolved.
- 0000476: [Shell Integration] Linux big tree in data/user folder - resolved.
- 0000488: [translation] Translation issues in Plugins - resolved.
