[APG 2.5 RC WIN64] rendering quality
Archive of all bug reports. This forum is closed - you cannot create new topics or comments here! If you think a specific topic was moved here by mistake, please contact the moderators!
hd_pano
by hd_pano » Mon Dec 20, 2010 6:58 pm
hello,
at my gigapixel test panorama i got with APG stitching errors, which i couldn understand ( one example: see first picture as a small extract of the picture). The global RMS in this picture was 2.93. The control points at the pairs of pitures were arranged over a large part and the RMS between this pictures was around 2.5, and no control points were worst then 5. I didn't know what to do.
For a test i exported the project as a PTGui file. Then i loaded the file to PTGui and let PTGui optimize it once. No control points were were shifted. Then i stitched it by PTGui (second picture). You can see PTGui didn't make this stitching errors. As far as i can see (it is not easy at a picture with more than 2 Gigapixel) i didn't found any stitching errors.
Btw i had the feeling that the picture from PTGui is more sharp especially at the overlap between pictures. Both pictures are an extract of the original PSB-file which comes direct out of the programs.
hd_pano
div lenses from 8 to 2000 mm
div cameras
div panoheads
div comuters
Liked in: 8 posts
by AlexandreJ » Tue Dec 21, 2010 9:32 am
Could it be possible to play with your test case ?
You have access to the ftp server for the upload : http://www.autopano.net/forum/t766-ftp-server
hd_pano
by hd_pano » Tue Dec 21, 2010 12:52 pm
i zipped all pictures, the papywizard xml-file and the the pano file in one file and startet uploading "files_hd_pano.zip"
In a fiew hours it will be ready.
regards hd_pano
div cameras
div panoheads
div comuters
hd_pano
by hd_pano » Wed Dec 22, 2010 8:37 am
it is ready.
good luck with the files.
If you have any questions, or need more infos ask it or you know my mail
regards hd_pano
div cameras
div panoheads
div comuters
