Image defect at (360°,0°) pano borderline
Archive of all bug reports prior to 2011. This forum is closed - you cannot create new topics or comments here! If you think a specific topic was moved here by mistake, please contact the moderators!
hermer-blr
by hermer-blr » Sun Dec 05, 2010 2:10 pm
Config: I am running APG beta2 on a windows 32 bits configuration
For the second time in a few weeks, I note that there may by correction errors at the (360°, 0°) borderline of the panorama:
- In one case, a few weeks ago, the stitching was bad and I had to rotate the center of the pano in APG to change the (360°, 0°) borderline position - the stitching error was then corrected and the new pano went OK
- In the present case, the stitching is OK, but the sky is a different color on both sides of this borderline.
I don't want to rotate the pano before stitching for aesthetic reasons. And I have no time to wait until bug correction.
Is there any tool that I could use with Gimp (I don't have photoshop) to perform a circular rotation of the panorama ? I would then be able with the Gimp toolbox to correct the defects in the sky. And, by using the same tool, I would put the pano back in its initial position.
J.M.
Windows 32 bits - APG
website htt://jmh.trp.free.fr
by AlexandreJ » Mon Dec 06, 2010 11:48 am
Hi Hermer.
This seems to related to issue 405 that is solved for RC version.
hermer-blr
by hermer-blr » Mon Dec 06, 2010 1:11 pm
Thanks - Any solution to perform a circular shift on the 10000 x 5000 image I get ?
In this specific case, I can improve the sky by image processing; but, I need the defective area at the centre of the image...
After that image processing, for aesthetic reasons, I will have to revert the circular shift to come back to the original image.
Thanks for helping me
by GURL » Tue Dec 07, 2010 9:02 pm
hermer-blr wrote:I don't want to rotate the pano before stitching for aesthetic reasons. And I have no time to wait until bug correction.
I'm not used to GIMP but believe that "rotation" of 360 panos using any image processor are as easy as:
- cut the pano into 2 halves using a vertical guide (that the parts are equal or not don't matter)
- place the right part at the left of the left part: they will match perfectly because it's a 360 pano...
hermer-blr
by hermer-blr » Wed Dec 08, 2010 1:29 pm
Unfortunately, this does not work well, especially if you are confronted to big images (with the inherent difficulty of interactive movement).
Since my post, I found an easy solution:
- transform the image to polar coordinate, with 180° angle
- transform the image back, with 0° angle
Done ! The pano is 50 % circular shifted !
