Problem of "dirty zone" after rendering
Archive of all bug reports prior to 2011. This forum is closed - you cannot create new topics or comments here! If you think a specific topic was moved here by mistake, please contact the moderators!
mountaintb
by mountaintb » Sun Oct 31, 2010 4:26 pm
I have a problem of rendering, my pano is OK on the edit window, but when I render it the result is quite dirty specially in the skyes, I keep all the setting where they are initially...
See on the exemple above :
MTB
mountaintb
by mountaintb » Sun Oct 31, 2010 4:27 pm
It appears specially in the sky over the trees.
mountaintb
by mountaintb » Sun Oct 31, 2010 4:29 pm
by GURL » Sun Oct 31, 2010 6:55 pm
Which version ?
Which Blending pressets ?
See http://www.autopano.net/forum/t10206-2.5-beta-1-remove-ghost-option-changes-result-brighnest
You could try to deselect Remove ghosts option if it was selected.
mountaintb
by mountaintb » Mon Nov 01, 2010 11:22 am
Georges, c'est Beta 2 et antoghost.
mountaintb
by mountaintb » Mon Nov 01, 2010 11:28 am
I am going to try to change the settings
mountaintb
by mountaintb » Mon Nov 01, 2010 12:12 pm
I am testing different level of the antighost and I will show the results on this topic.
mountaintb
by mountaintb » Wed Nov 03, 2010 11:10 am
So here it is, I have render the same pano (87 images on 3 rows of 29 images) at different levels of the anti-ghost.
This one is at -2 the "normal setting" :
mountaintb
by mountaintb » Wed Nov 03, 2010 11:15 am
So here we are, the first sample of the same image (87 images on 3 rows of 29 images) is at normal anti-ghost level "-2", you can see the dirty sky and the strange effect in the tree :
mountaintb
by mountaintb » Wed Nov 03, 2010 11:17 am
The second one is at "-4", the dirty effect has almost vanished and the lighter zone also, but it's not perfect :
mountaintb
by mountaintb » Wed Nov 03, 2010 11:19 am
That one is at -6, not perfect neither and you start to see the different limits of images in the sky :
mountaintb
by mountaintb » Wed Nov 03, 2010 11:21 am
And finally I have tried at "0", the different images in the sky is very present :
mountaintb
by mountaintb » Wed Nov 03, 2010 11:24 am
The problem is in between the second and the third raw that is basically sky, with a few details of the second raw, is it part of the problem???
I love the new 2,5, for the detection it's absolutly perfect, but I have a problem with that anti-ghost......
mountaintb
by mountaintb » Wed Nov 03, 2010 5:51 pm
Alexandre, do you have any idea of what's happening????
by AlexandreJ » Wed Nov 03, 2010 6:00 pm
Without input files, it will be hard to test myself. Seems to be a blending issue with one image, but I cannot be sure.
Could you convert all images into jpeg and put them on ftp ?
le_grux
by le_grux » Wed Nov 03, 2010 7:29 pm
I have also this issue... if interested in having the images, let me know
Best regards
Jean-Yves GRUFFAT
Cordialement / Best Regards
Jean-Yves GRUFFAT
by AlexandreJ » Thu Nov 04, 2010 2:43 pm
I did an in depth review of that case and it appears that the way we calculate the number of pyramid level was not the same as the one done before by smartblend. This old algorithm is doing less levels than we did ( or saying other way, we are doing too much levels compared to the old algorithm ).
When looking at the results carefully, it seems that we do too much. See the following screenshots : it's level 0 ( meaning the maximum number of levels ), level -4 ( meaning all except 4 last levels ) and -2 ( meaning all except 2 last levels ).
It appears that the right settings is -4 ( which could be compared to the real 0 of smartblend ).
So we have 2 solutions : either we change the way we calculate the level max level to correspond to smartblend, or we change the default setting to -4 for multiband in the new engine.
Both solution are okay in fact. So for Thierry, just switch to -4 and it will be okay with beta 2.
