[AGP 2.5B2 W7] Still crash with Neutralizer & NEF files
gmargue
by gmargue » Tue Oct 26, 2010 9:40 am
Hy;
I still have the same problem with B2 (issue 242 in B1) :
The first Hazed file is generated but all dark and then the crash :
Microsoft VC++ runtime library
Tuntime error
This application has requested the runtime to trminat it in a unsusual way...
by AlexandreJ » Tue Oct 26, 2010 9:46 am
Issue 242 reopened
llang57
by llang57 » Tue Oct 26, 2010 12:36 pm
bonjour Alexandre,
même problème sur Xp ou vista avec des raw (sony) ou des jpegs de 24 Mpix (6000x4000 pixels)
mais rien n'est généré.
Sur Vista 64 sur un autre poste je n'ai même pas d'affichage de la vue splittée (avant - après) j-ai une moulinette qui tourne indéfiniment (plus de 10 minutes - après j'ai arrété)
Amicalement
gmargue
by gmargue » Fri Oct 29, 2010 11:34 am
Alexander,
I have the same problem with TIFF files generated with DXO.
The first generated hazed file is completely dark and after the system crash (same C++ error code) and APG closed.
No more hazed files were generated
renan
by renan » Fri Oct 29, 2010 1:27 pm
is it possible to upload two of your nef or tiff files in our ftp, I have not reproduced this with my own files :
http://www.autopano.net/forum/t766-ftp-server
gmargue
by gmargue » Fri Oct 29, 2010 4:40 pm
No problem, it's in progress (pdHaze.zip).
Did you get it now ?
renan
by renan » Tue Nov 02, 2010 3:14 pm
I get it.
Pictures was neutralized in first try...
But I produce two cases of crash :
* do not press finish if a preview is under computing
* verify if you have enough space on disk (or if the directory is protected for writing)
gmargue
by gmargue » Wed Nov 03, 2010 8:10 am
I did complementary tests:
- I work on the disk which have the system (W7) (enough space and not protected for writing).
- I press finish only when there's no preview under computing.
- I also try to run APG in compatibilty Windows XP mode.
If I try to "Neutralize" just one RAW file, it seems OK
If I try to "Neutralize" two RAW files at the same time, the first generated Tiff seems to be OK, the second generated Tiff is completly dark.
If I try to "Neutralize" three RAW files, then the crash comes.
