[APP 2.5 B2 MAC] No Color Correction
machart
by machart » Tue Oct 26, 2010 9:36 am
Thank you for the new version, which has a lot of problems fixed!
But one thing seems to be broken: the color correction gives a strange preview! here some screenshots with and without LDR:
::: close to the rainbow :::
D300S, 18-200mm, 10,5mm, NN3, iMac i7
http://panographie.net
by AlexandreJ » Tue Oct 26, 2010 9:47 am
That's issue 358
Bmachine
by Bmachine » Tue Oct 26, 2010 5:05 pm
Yes, I am having the same problem. I did not see this in Beta 1...
Bo
iMac 27. OS 10.8.5. Aperture, APG, PS and Lightzone.
Nikon D600. Mostly handheld.
geko5766
by geko5766 » Tue Oct 26, 2010 5:16 pm
Same Problem here.
Windows Vista, 64bit, 4 GB RAM
The Import via PW-plug-in is pefect. (AND VERY QUICK!!!!!)
The outcome is: #1
After setting to No-Color-Corrrection: #2
HDR Correction does not work either unfortunatelly.
I guess, you´ll have to release a quick-batch for that, as Color-correction is imperative....
Best regards
The picture is made behind the camera.......
Bmachine
by Bmachine » Tue Oct 26, 2010 5:29 pm
Yes, would it be possible to get a quick fix for that. This is a major show stopper...
Thank you very much.
I have to go back to Beta 1 because of that... :-(
Bo
geko5766
by geko5766 » Tue Oct 26, 2010 5:35 pm
Addendum to my observation:
After importing an OLD project, this behaviour does NOT occur!!!
The pano is properly shown.
BEst
geko
machart
by machart » Tue Oct 26, 2010 6:10 pm
Addendum also!
did a dozen of panos and it occured only on 7 ones... strange...
