Panogear and Windows 8 compatibility ?
OlivierDI
by OlivierDI » Fri May 16, 2014 1:56 pm
Since upgrading to windows 8 the Panogear does not connect with Bluetooth anymore.
Any troubleshooting beetween panogear and windows 8 ?
And is there another mean to connect ?
Thanks,
PS : sorry for my bad English ;)
Re: Panogear and Windows 8 compatibility ?
by mediavets » Fri May 16, 2014 2:05 pm
What controller are you using?
Papywizard? or something else?
OlivierDI
by OlivierDI » Fri May 16, 2014 2:08 pm
Thank for your answer,
Yes Papywizard.
by mediavets » Fri May 16, 2014 2:14 pm
OlivierDI wrote:Thank for your answer,
Yes Papywizard.
And you are using the PapyMerlin Bluetooth adapter on the Panogear/Merlin mount?
Are you using a 32-bit or 64-bit version of Windows 8.1? (you are using 8.1?)
Are you using a built-in BT adapter on your computer or an external BT USB 'dongle'?
Are you using standard Microsoft Bluetooth driver on your computer or is it some third-party Bluetooth stack. Papywizard doesn't 'like' some third-party Bluettoth stacks.
I have just run a test and I have Papywizard (last dev version) running on Windows 8.1 Pro 64-bit using a Bluenext branded 'generic' type BT USB dongle and a Merlin (Panogear) mount with the PapyMerlin Bluetooth adapter.
Pairing and getting to BT adapter settings on the PC can be a bit of a challenge (for me anyway as I'm still more familiar with XP) because one gets thrown into some Metro/TIFKAM-UI stuff along the way.
If you cannot get a BT connection to work, try a serial-over-BT connection.
