Panogear : noicelevel
Bjarne Nybo
by Bjarne Nybo » Thu May 01, 2014 2:28 pm
My new panogear makes quit a lot of noice by pan.
Especially by panning quickly and at the functions where I want to pan vertical by the upper revolving module which makes noise when running.
Do you recommend that I en one or another way use Spray Duster (air with oil)?
If ”yes” is it recommendatory to amount the cover?
On beforehand thank you very much with my best photoregards Bjarne
Re: Panogear : noicelevel
by mediavets » Thu May 01, 2014 2:33 pm
I have two Merlin (marketed by Kolor as Panogear) mounts
The motors and gears on a Panogear/Merlin mount are quite noisy.
Did you expect them to be silent?
I would not recommend that you attempt to lubricate them in any way.
Bjarne Nybo
by Bjarne Nybo » Thu May 01, 2014 2:41 pm
I expect them to be a lidt bit silent - but not 100 %
Thanks: Bjarne
by klausesser » Thu May 01, 2014 4:22 pm
mediavets wrote:I would not recommend that you attempt to lubricate them in any way.
I definitely agree!! Wouldn´t make sense anyway: the gear is plastic as i remember.
It could be less noisier by running much slower . . . but i guess that´s not what
you would like really . . . :cool:
In the slowest mode you can´t hear it at all - but you also can hardly see it moving at all . . .
takes hours for one 360 turn =D :cool:
You can try to glue damping mats onto the inside of the body´s plastic parts - battery compartment and vertical arm -
but i doubt it would really help much.
Bjarne Nybo
by Bjarne Nybo » Thu May 01, 2014 7:00 pm
Oh, the gear is plastic, so I agree.
Thanks. Now I will go to take some picturers - a lot of.
Bjarne
