Clauss generated txt file
shayke
by shayke » Mon Feb 10, 2014 4:17 pm
Does anyone have a sample of a .txt file generated by CLAUSS panohead after the shooting?
I need to be familiar with its structure and content
Thanks,
Shay
Re: Clauss generated txt file
by gkaefer » Fri Apr 18, 2014 9:25 pm
shayke wrote:Hi,
Thanks,
Shay
not 100% sure, but looks like:
(myself using now panoneed panohead, also papy comp. XML fileformat)
according to dr clauss Homepage, clauss panoheads are compatible with papywizard XML files. So download paywizzard use the offline mode and generate XML files with the pattern you like. save the XML open it... :cool:
see also here:
http://www.autopano.net/wiki-en/action/ ... _data_file
