Bad day , Dropped Handheldcontroler
rolly1
by rolly1 » Thu Jan 30, 2014 10:24 pm
=( =( Is it possible to get it repaired or get the parts , I think all it needs is a new Display =( =( cheers rolly1
Re: Bad day , Dropped Handheldcontroler
by klausesser » Thu Jan 30, 2014 10:56 pm
rolly1 wrote:=( =( Is it possible to get it repaired or get the parts , I think all it needs is a new Display =( =( cheers rolly1
Can you be a bit more specific? What "handheld controller" are you talking about? T&C? Original Orion? N800/810?
rolly1
by rolly1 » Thu Jan 30, 2014 11:17 pm
hi Klaus hope you are well, the panogear t & c the one before panoshoot the little tag on the phone plug must have broken off I bumped it with my arm and it fell out on to road ,and now the Display has a black line across it and of course it does not work any more but I did get the xml files out of it ok rolly1
by klausesser » Thu Jan 30, 2014 11:35 pm
rolly1 wrote:hi Klaus hope you are well, the panogear t & c the one before panoshoot the little tag on the phone plug must have broken off I bumped it with my arm and it fell out on to road ,and now the Display has a black line across it and of course it does not work any more but I did get the xml files out of it ok rolly1
Send it to Josef he´ll fix it! Adress per PM.
good luck, Klaus
rolly1
by rolly1 » Fri Jan 31, 2014 3:41 am
many tnx Klaus I will do that cheers rolly1
rolly1
by rolly1 » Thu Feb 06, 2014 2:37 pm
still no reply from Josef ,will send another email cheers rolly1
by klausesser » Thu Feb 06, 2014 2:42 pm
rolly1 wrote:still no reply from Josef ,will send another email cheers rolly1
That´s very uncommon. Sure you typed the adress correctly?
I´ll ask him. What name did you use? "rolly1"?
by klausesser » Thu Feb 06, 2014 2:47 pm
Talked to Josef a minute ago: he didn´t get any message from you!
here again his mail-adress: rgraessle@t-online.de
rolly1
by rolly1 » Thu Feb 06, 2014 11:09 pm
Hi Klaus I used my real name but I added rolly1 as well I will try again today cheers rolly1
