Presets
alvareznavalon
Presets
by alvareznavalon » Fri Jan 03, 2014 7:13 pm
Someone has the preset for Samyang 8 mm lens?
claudevh
Re: Presets
by claudevh » Wed Jan 29, 2014 10:36 pm
Hello Alvarez,
Samyang | 8mm
VFOV (max - min) 185°
HFOV (max - min) 185°
DFOV (max - min) 185°
Shooting Set-up
Recommended 1.5x crop 4 photos every 90° at 0° + Z + N
The Best way to operate is on a monopod turning by hand every 90°
Not necessary to use a Merlin/Panogear for this kind of picture ...
Re: Presets
by klausesser » Thu Jan 30, 2014 12:09 am
claudevh wrote:Not necessary to use a Merlin/Panogear for this kind of picture ...
It´s rather counterproductive using a merlin with a fisheye. It´s base is so large that a very big Nadir-hole occurs.
Also in terms of speed a manual head is preferable.
XML files for positioning is obsolete in 95% of all cases using a fisheye - it´s FOV is so wide that correct matching control points usually can be found automatically.
Re: Presets
by mediavets » Thu Jan 30, 2014 9:54 am
Unless your setup is such that you cannot reach the pano head to reposition it - shooting on a pole, and so on.
Re: Presets
by klausesser » Thu Jan 30, 2014 10:46 am
Using a fisheye on a pole the Merlin´s big base gets even worse. I tested it years ago: the bigger the head´s base the lesser you see from the ground - which is quite logic.
And that´s definitely not what you want using a pole . . .
No - for shooting with a fisheye on a pole better use either a motorized head providing a rather small Nadir-hole - Seitz, Dr. Clauss, Panoneed - or use a manual head with the camera set slightly angled or just a ring and put marks on the lower part of the pole for orienting during spinning the pole. That´s common use.
The problem with a manual rig on a pole is shooting the Zenith - but there are tricks which help here.
Believe me: using the merlin on a pole with a fisheye really is suboptimal . . i realized that by doing it ;)
Re: Presets
by mediavets » Thu Jan 30, 2014 11:03 am
You are correct of course.
I was really 'talking generically' about fisheye lenses and robotic pano heads.
Re: Presets
by klausesser » Thu Jan 30, 2014 12:23 pm
mediavets wrote:You are correct of course.
I see. The Merlin is somewhat "special" in the range of pano-heads. But it´s a great device!!
best to you, Klaus
