mediavets wrote:martinii007 wrote:I wrote one more times my list:
1. Full frame camera Canon 6D
2. Sigma 15 F2.8 EX DG Fisheye
3. Software - Autopano Giga and Panatour Pro 1.8 with Upgrade.
4. Manfrotto 055XPROB with levelling centre column
It that's all? Or I forgot something?
I have Computer with i7, geforce graphic card and SSD and big monitor.
When I buy equipment I Sign up for a course. But everyone must have their own equipment.
You have forgotten the pano head - it was to be an NN4 with R-D16 and nadir adapter I believe, and possibly a camera-specific Arca Swiss compatible QR.
Artisan S. wrote:If you wanna go to 2 to 50 and even 350 Gpixels (and I still have to find the point in doing so) obviously you need a maxed out computer (and maxed out everything else including easily forgotten SKILLLLLL).
Artisan S. wrote:>You NEED a "robotic" head writing xml files<
Yeps Klaus, but the .xml can be faked if you know how you shot the pano manually (degrees per step horizontal, degrees per step vertical, number of shots horizontal, number of shots vertical and of cause the most important variable the focal lengt used, and last but not least the steps HDR that were used)......but that requires some knowledge about .xml files and the way Kolor interprets them and is far from easy, nor is shooting a 30.000 x 24.000 picture using a manual head a comfortable affair (very, very exhausting work due to the concentration involved). So I'm currently writing (wenn die Affenhitze nachlest) a .xml part in my code and I'm building my own head (with a little help in the hardware department).
Artisan S. wrote:2) You NEED real good lenses - i suggest primes, no zooms.
3) You NEED a VERY good tripod - we´re entering a region *starting* from about 300.- here.
In fact Klaus I guess you use manual focus lenses quite often (Nikon on Canon as I recall). That sure saves money since good quality manual glass can be bought a rock bottom prices.
Artisan S. wrote:About the FF-ness....well some gigapans are made with 7D's and as memory serves the London 360 pano is made with this APS-H camera.....simply because a smaller sensor "extends" the lenses (and also extends the DOF) which makes gear lighter at the same magnification.
But FF sensors have something ahead, a bit more bitdepth which gives much nicer color rendition.
