Panogear - compatibility
martinii007
by martinii007 » Mon Jul 22, 2013 12:20 pm
Is the kolor Panogear compatible with Canon EOS 6D?
by mediavets » Mon Jul 22, 2013 3:15 pm
martinii007 wrote:Hi,
Welcome to the forum...
If you wish to mount the camera in portrait orientation at the NPP without modifiying the dovetail clamp or the camera rail then the dimension from the base of the camera to the centre of the lens mount, must be 40mm or less, AND the diameter of the lens barrel must be 80mm or less.
If you are planning to shoot relatively distant outdoor scenes - where nothing in the scene is within say 100m - with long focal length lenses, then mounting at the NPP is irrelevant and it's more important to mount the camera/lens combination close to the centre of mass.
What len(es) did you plan to use?
How did you plan to control the mount - with Papywizard (if so which platform/OS), with Panoshoot, with the T&C Touch controller?
martinii007
by martinii007 » Mon Jul 22, 2013 8:07 pm
I want to buy Samyang 8 mm f/3.5 and Panogear with Camera will be controled with Papywizard (Windows).
by mediavets » Mon Jul 22, 2013 8:24 pm
martinii007 wrote:I want to buy Samyang 8 mm f/3.5 and Panogear with Camera will be controled with Papywizard (Windows).
Why did you plan to use a robotic pano head with your Canon 6D and Samyang 8mm fisheye lens?
The widely accepted view is that it's not worth using a Panogear robotic head with a fisheye lens.
You need so few shots to cover 360 x 180 degrees panoramic field of view when shooting with a fisheye and the Panogear robotic mount has a much larger nadir footprint that a manual pano head.
A Nodal Ninja 4 manual pano head would suit your camera/lens setup very well.
Robotic pano heads, with shooting position recording, such as the Panogear (or the higher performance and cost Panonned and Seitz VRDrive) come into their own when you are shooting withn longer focal length stnadrd/rectinear lenses when you may need to shoot many tens or hundreds of images to cover your desired field of view - typicallya partial pano with a field of view of considerably less than 360 x 180 dgrees.
The shooting positions recording can be used later when stitching with APP/APG (or PTGui) to help the stitcher place 'featureless' images that would otherwise be left out of the stitch.
martinii007
by martinii007 » Mon Jul 22, 2013 9:11 pm
You're right. I buy a Nodal ninja to make a Virual tours and a Fisheye lens to D6.
The second lens will be able to make a gigapanoramas with robotic panohead. What a len I must have to make an optimal gigapanoramas, which is the best?
btw. When I want to buy a maual Panohead what are the differences by Nodal Ninja 4 and e.g. Ultimate M1-L?
by mediavets » Mon Jul 22, 2013 10:08 pm
martinii007 wrote:You're right. I buy a Nodal ninja to make a Virual tours and a Fisheye lens to D6.
OK. You may wish to check out the Bushman Gobi manual pano head that Kolor is now offering too.
What is an 'optimal gigapanorama'?
A prime lens, not a zoom, for start. Then it just depends on the resolution of panoramic image you wish to produce really, the longer the focal length the higher the res. of the stitched pano....but the shooting phase though often challenging is nothing like as challenging as the processing - you need powerful hardware to handle very high res. panos and the process becomes exponentially more difficult as focal length increases.
You can produce quite nice medium-high res. panos with a 50mm prime (they are relatively inexpensive too).
Relatively few pano scenes seem to 'justify' the multi-gigapixel treatment, and is there any point in producing very hi-res. panos just for the sake of it?
btw. When I want to buy a manual Panohead what are the differences by Nodal Ninja 4 and e.g. Ultimate M1-L?
IMO the Ultimate would be 'overkill' for use solely with a Canon 6D and and Samyang 8mm fisheye, in fact some would say the NN4 is rather 'more' than you need too.
But if you have money burning a hole in your pocket...
martinii007
by martinii007 » Tue Jul 23, 2013 8:14 am
I mean: what is an optimal len to make a panoramas or gigapanorama's?
What you think about Nodal Ninja 4 + Leveler II + Rotator RD16 + Nadir adapter?
To my D6 are to Ninja 4 also Camera plates?
I see that, you have a SIGMA 8mm F/3.5 Fish Eye len. Are large differences between Sigma 8mm lens and Samyang 8mm?
by mediavets » Tue Jul 23, 2013 2:12 pm
martinii007 wrote:I mean: what is an optimal len to make a panoramas or gigapanorama's?
I think I answered that already? Don't use zoom lenses and pick a focal length that when combined with your camera's sensor resolution will give you a panorama of the desired resolution?
But remember that it's quite easy to end up shooting a hi-res pano that you don't have the hardware to process effectively.
So I would suggest you start with a 'sensible' focal length, say 50mm, and learn the ropes before embarking on something more ambitious.
I wouldn't bother with the leveller. You can quite easily level a tripod more or less manually and easily level a pano in APP/APG. A tripod with a levelling centre column would be more useful than the NN Leveller IMO.
If you are only going to shoot with a fisheye then the R-D16 is overkill but for some reason NN don't offer the NN4 with an R-Dx rotator with fewer click stop options these days. There used to be an R-D8 but they don't offer the NN4 with the R-D5 as far as I know (that is if the R-D5 is even compatible with the NN4).
I don't understand the question.
Yes, they are very different 'beasts' - the Sigma produces a cropped circular image on cropped sensor , the Samyang produces a fullframe fisheye image on a cropped sensor. The Sigma is also MUCH more expensive. The Samyang is a fully manual lense too on the Canon body.
martinii007
by martinii007 » Tue Jul 23, 2013 6:31 pm
Sorry for my English :|
If I buy NN4 I must buy a camera plate or not?
http://shop.nodalninja.com/camera-plate-arca-swiss-style-cp-c2-f2112/
At the moment I'm beginner but I want to make professional panorama's and virtual Tours's. That I want to have a professional equipment.
What you think about my "virtual-tour" and "panorama" equipment?
1. Full frame camera Canon 6D
2. NN4 with rotator and nadir adapter
3. Sigma len 8mm F3,5 EX DG Fisheye
4. Software - Autopano Giga and Panatour Pro 1.8 with Upgrade.
5. I have problem with Tripod, maybe this? Manfrotto 190X pro with levelling centre column
6. Second len to panorama's with robotic pano head. Maybe Sigma 85 F1.4 EX DG HSM?
Thanks a lot for your help :)
by mediavets » Tue Jul 23, 2013 6:42 pm
martinii007 wrote:At the moment I'm beginner but I want to make professional panorama's and virtual Tours's. That I want to have a professional equipment.
Good.
OK. That's with the R-D16 rotator?
Not with a fullframe camera - sorry I'd not spotted that 6D is fullframe before, being a 'dumb' Nikon shooter. You would be better off with the 'old' Canon 15mm fisheye if you can find one, or the new Canon 8-15mm zoom fisheye, or the Signma 15mm fisheye. Sigma 8mm produces a full circular image ona full frame sensor and 'wastes' a lot of pixels.
OK.
Manfrotto 055XPROB with levelling centre column would be better. There are more expensive options too.
Why not? Perhaps someone more familiar with Canon lens options will add their thoughts too.
by mediavets » Tue Jul 23, 2013 6:53 pm
martinii007 wrote:If I buy NN4 I must buy a camera plate or not?
Only if you wish to have an Arca Swiss compatible quick release on the upper arm of the NN4.
In which case you need two parts:
1. A camera-specific compatible plate to go on the camara - and I belive that the one you linked to is not the correct plate, in fact NN don't yet specififcally list a plate for the D6 - you'd need to contact them for advice.
http://shop.nodalninja.com/plates/
2. The compatible QR clamp to go on the upper arm:
http://shop.nodalninja.com/clamps/
by gkaefer » Tue Jul 23, 2013 6:58 pm
8mm on a fullframe Canon 6D? this gives you only small (less Pixels) final panos. I would pickup a 15-25mm lens (no zoom, fix focal, Fisheye or no fisheye....).
85mm as second lens? no this gives you gigapixel Panoramas you've no practise with. (Manual head & gigapanos... pain, merlin & gigapanos may work if you modify the merlins crow to get perfect NPP, so for gigapixel panos I would tend to go pr Quality like seitz head, panoneed in the 2-3K€ class or even some more expensive head in the +3K€ class)
I would pickup the Canon EF 24-70mm f 2.8L II - USM. this lens you can Keep with you even if you upgrade your Body in 1-3 years...
martinii007
by martinii007 » Tue Jul 23, 2013 7:14 pm
OK.
2. Sigma 15 F2.8 EX DG Fisheye
3. Software - Autopano Giga and Panatour Pro 1.8 with Upgrade.
OK.
4. Manfrotto 055XPROB with levelling centre column
5. Second len to panorama's with robotic pano head. Maybe Sigma 85 F1.4 EX DG HSM? Can you give another example?
It that's all? Or I forgot something?
by mediavets » Wed Jul 24, 2013 9:41 am
OK.
OK.
Can you tell us more about the sort of panos you hope to shoot and whether this is to be a hobby or a commercial activity?
THis information might lead me to suggest additional items for your list.
Do you already have the Canon 6D?
martinii007
by martinii007 » Wed Jul 24, 2013 11:18 am
When I buy all elements I want to learn and offer commercial virtual tours and panorama's.
I have not bought yet Canon 6D but I want to have a FF Camera.
I read a lot of opinion that this Camera is very good and better than 5D mkII.
by mediavets » Wed Jul 24, 2013 12:23 pm
You are going to be spending a lot of money on a speculative venture.
Many have tried and failed to make a decent return on real estate panos and tours.
I hope you have done your marketing research, budgeting and business planning thoroughly.
Mots real estate agents also want regular still images...a wide angle standard/rectlinear lens is desirable for those...and to avoid lens swappping two bodies are helpful.
by klausesser » Wed Jul 24, 2013 12:43 pm
martinii007 wrote:When I buy all elements I want to learn and offer commercial virtual tours and panorama's.
I *strongly* suggest to learn about the basics of commercial panorama-photography BEFORE buying equipment.
martinii007 wrote:I have not bought yet Canon 6D but I want to have a FF Camera.
A FF-camera definitely is preferable for commercial use. I use a 5D2 for about 3 years now - it´s an excellent workhorse.
The 5D3 is better in terms of dynamic - but in my eyes ways too expensive just for panorama-shooting.
I´m gonna switch to a Nikon D800 these days . . i´m using Nikon-primes anyway.
I don´t know the 6D.
If you want to do more than fisheye panos of 6 or 8 shots - definitely preferable the 15mm or 8-15mm Canon fisheyes - and enter the
hires world you need to know some facts:
1) You NEED a "robotic" head writing xml files.
2) You NEED real good lenses - i suggest primes, no zooms.
3) You NEED a VERY good tripod - we´re entering a region *starting* from about 300.- here.
4) Yue NEED a VERY capable computer - many starters completely under-estimate this fact.
Let´s see:
Camera, Fisheye and two good primes for gigapixels (say: 85mm and 300mm) = around 6000.-€.
Computable head writing xml incl. controller: starting from 2000.-€ +VAT
Very sturdy tripod *starting* from about 300/400.-€
Computer/display/add-ons i guess in the PC-DIY-range and capable of gigapixel-panos a good start is around 3-4000.-€
So - and that´s just an optimistic guessing - in terms of commercially producing panoramas/gigapixels we´re talking about
an investment of around 10-12000.-€, including several helpful gadgets i didn´t mention here.
But first of all you need SKILLS and KNOWLEDGE.
Without having plenty of technical skills and theoretical knowledge AND being experienced in photography AND in marketing yourself as a
panorama-producer . . . . you most likely will burn much money.
Take this as a friendly advise from a pro instead of feeling insulted please (i encountered that sometimes . . ;):rolleyes:).
best and good luck, Klaus
PS: 75% of running this business sucessfully isn´t related to cameras, lenses and gadgets at all . . . . ;):cool:
martinii007
by martinii007 » Wed Jul 24, 2013 2:18 pm
mediavets wrote:Many have tried and failed to make a decent return on real estate panos and tours.
I will not ofer only virtual tour's. This will be an option of many other's services :)
Thank all users for quick reply's and suggestions and sorry for my English (I learn) :)
When I started I want to make only virtual tour's. First I must have a professional equipment, than I sign up for the course: how to make virtual tours.
When will my business succeed I buy equipment for gigapanorama's.
At the moment I please user's to make a list of professional equipment...
I wrote one more times my list:
I have Computer with i7, geforce graphic card and SSD and big monitor.
When I buy equipment I Sign up for a course. But everyone must have their own equipment.
by mediavets » Wed Jul 24, 2013 2:45 pm
martinii007 wrote:I wrote one more times my list:
You have forgotten the pano head - it was to be an NN4 with R-D16 and nadir adapter I believe, and possibly a camera-specific Arca Swiss compatible QR.
martinii007
by martinii007 » Wed Jul 24, 2013 2:58 pm
mediavets wrote:You have forgotten the pano head - it was to be an NN4 with R-D16 and nadir adapter I believe, and possibly a camera-specific Arca Swiss compatible QR.
YES of course :)
What you think about this equipment to make virtual tours, scale from 1-10?
by mediavets » Wed Jul 24, 2013 3:28 pm
YES of course :)
I'd give it at least an 8, and I'd be very envious.
Why an 8? Some would opt for a more expensive tripod perhaps, and some might opt for adding a Promote Control for even more extstive expsoure bracketing.
Although not absolutely required for VTs I'd like to add a wide angle rectilinear lens if I was going to do a lot of real estate work; even with VTs you don't always want to offer a full 360x180 ,say, a small ensuite shower room a regular wide angle single image willconvey enough info, and same approch canm be useful to highlight features within a larger space..
Artisan S.
by Artisan S. » Wed Jul 24, 2013 6:00 pm
>I´m gonna switch to a Nikon D800 these days . . i´m using Nikon-primes anyway.<
Well done Klaus.....my nephew uses a D800e.....but I fankly don't see hell of big difference between the D800 and D800e after some sharpening to counteract the AA filter.
Greets, Ed.
Fear leads to anger, anger leads to hate, hate leads to... suffering (c) Yoda.....
Olympus OM-D with HLD-6, Fuji GX680, Samyang 7.5, Olympus 9-18, Sigma 19, Panasonic 14-45, Nikon 50 1.4 on Novoflex with tripod mount, Nikon 80-200, Panasonic 45-200, Fujinon 135, Fujinon 80, Fujinon 65, Fujinon 50, Gitzo Gilux Reporter 2, Sirui Ballhead and Panosaurus 2.0 NNP adapter, Arduino Uno.
Artisan S.
by Artisan S. » Wed Jul 24, 2013 6:26 pm
>4) Yue NEED a VERY capable computer - many starters completely under-estimate this fact.<
That depends on two things......size of the pano's a 30.000 x 24.000 pano can be made using a good tele and a middle of the road computer. But that is not Gigapano but is still printable at 720 Gpixel about the resolution of an 8 x 10 inch camera and define a printsize of 100 inch or 2 x 2,5 meters (big enough I should say). And time willing to sit stairing at a progres bar.....now and that depends on wether you do this as an artform (as I am willing to) or as a commercial enterprise.....commercial implies deadline, deadline + slow equipment + errors and try-outs implies stress, stress implies an early grave,. death by pano so to speak. If you wanna go to 2 to 50 and even 350 Gpixels (and I still have to find the point in doing so) obviously you need a maxed out computer (and maxed out everything else including easily forgotten SKILLLLLL).
If you are new act new. Learn first, buy later. It makes no sence to buy a 4000 dollar + rodeon (or even a 3000 dollar+ Panoneed) if you have no clue for what you are gonna use it. Shooting Pano's is about as complex and wide a field as is photography itself.
>You NEED a "robotic" head writing xml files<
Yeps Klaus, but the .xml can be faked if you know how you shot the pano manually (degrees per step horizontal, degrees per step vertical, number of shots horizontal, number of shots vertical and of cause the most important variable the focal lengt used, and last but not least the steps HDR that were used)......but that requires some knowledge about .xml files and the way Kolor interprets them and is far from easy, nor is shooting a 30.000 x 24.000 picture using a manual head a comfortable affair (very, very exhausting work due to the concentration involved). So I'm currently writing (wenn die Affenhitze nachlest :)) a .xml part in my code and I'm building my own head (with a little help in the hardware department).
No argument there.....but you don't have to buy AF lenses as well. In fact Klaus I guess you use manual focus lenses quite often (Nikon on Canon as I recall). That sure saves money since good quality manual glass can be bought a rock bottom prices.
About the FF-ness....well some gigapans are made with 7D's and as memory serves the London 360 pano is made with this APS-H camera.....simply because a smaller sensor "extends" the lenses (and also extends the DOF) which makes gear lighter at the same magnification.
http://thenextweb.com/shareables/2013/02/20/360-degree-panoramic-photos-of-london-smashes-world-records-with-48640-frames-carrying-320-gigapixels/
But FF sensors have something ahead, a bit more bitdepth which gives much nicer color rendition.
Greets, Ed.
P.S. My advice.......buy a good manual head first and learn the basics of VR spheres and Gigapano's and let investment and ambition grow together with experience, knowledge and skill. Used to play guitar and thought a 5000 dollar guitar and a 3000 dollar amp would turn me into Carlos Santana.......it did not, I played just as bad, and sold the whole #### at rockbottom prices, frustrated......auwch....
Greets, Ed.
Artisan S.
by Artisan S. » Wed Jul 24, 2013 6:35 pm
>even with VTs you don't always want to offer a full 360x180 ,say, a small ensuite shower room a regular wide angle single image willconvey enough info<
Very wise spoken Andrew, with a single shot you are able to COMPOSE a picture and that means leaving out the not so starteling parts of a room. And sometime in order to present something you don't really want the deep honnesty and degree of intamecy a VR sphere creates. It an imersive but also invasive and revealing art. Home owners (and home sellers) have to keep that in mind. A good panographer knows when he or she adds to the salebility and when he substracts. Have seen more then my share of appartments and believe me not all them were instantly sellable via VR.
Greets, Ed.
Artisan S.
by Artisan S. » Wed Jul 24, 2013 6:36 pm
Greets, Ed.
Greets, Ed.
